Pulsing just off idle?
Old Sep 24, 2018 | 07:20 PM
Fla Steve's Avatar
Default Pulsing just off idle?
So after my catch up maintenance I took a 50 mile drive today. I'm experiencing a hesitation just off idle and a little pulsing at minimal throttle input. It picks up with just a tiny bit more throttle. I set the butterflys at .002, and adjusted all the slack out of the throttle rods. Is this a sign of a throttle potentiometer out of adjustment or a worn contact area? Could someone give me a link in the Forum on how to adjust the TPS please.....PS. I made homemade coolant filters (temporary) and it got up to 230F before I could get home. (Took a big risk I guess) Pulled the screens and they were clogged.
RH 75% clogged
LH 90% clogged
Old Sep 24, 2018 | 08:55 PM
baxtor's Avatar
Is your car fitted with the idle microswitch, if so is that adjusted correctly?
Old Sep 24, 2018 | 09:53 PM
JigJag's Avatar
Baxter, what’s this ‘idle microswitch’? None here. What’s it do?
Fla Steve, A TPS out of adjustment or with worn contact will cause a hesitation right at throttle opening.
Old Sep 24, 2018 | 10:04 PM
Doug's Avatar
Marelli cars only. Allows closed throttle "timing strategy"
Old Sep 25, 2018 | 02:48 AM
VancouverXJ6's Avatar
Do you need a better more permenant coolant filter solution? I'm a loud advocate for these both on old cars and my diesel work trucks.
Lots of options but my god if thats what you pull after 50 miles imagine the **** in the system...rad...heater core.
The tebfa metal strainers are junk. In line full flow servicable magnetic filteration is needed.
pm me I can link you to some stuff on that subject.
Old Sep 25, 2018 | 04:35 AM
Here ya go.
AND
NO slack it those throttle rods is WRONG, and will cause what yo have once warmed up.
File Type: doc
File Type: doc
Old Sep 26, 2018 | 09:00 AM
Fla Steve's Avatar
Thank you Grant. I do have the Idle Micro switch and adjusted it to open just after the throttle rods start to move the butterflys. Guess I have a bit of fine tuning to do.
Old Sep 26, 2018 | 07:51 PM
Drink MORE, things always clear up the MORE you drink,
Good luck.
Time setting all that up is the key, and it does take time.
Always remember, it is 2 X 6cyl engines on a common crankcase, and with that firmly in the brain, it is soooooo simple.
crumble
Sep 6, 2014 12:06 PM
crumble
Apr 9, 2013 12:36 PM
Duncan2004
Feb 20, 2013 05:36 PM
Ipc838
Jun 26, 2012 02:50 PM
OUR CAT
Oct 1, 2009 09:34 PM
