Radiator Bleeding: Old Faithful Gushing Green
Old Jun 2, 2010 | 04:16 PM
michaem101's Avatar
Default Radiator Bleeding: Old Faithful Gushing Green
I followed Doug's bleeding procedure and when I started her after filling (all caps and bleed screw off), she was immediately gushing green from the filler tube. Got all over the engine compartment. This is scary with all those crispy wires and electrical parts everywhere...I cut the engine.
Is this normal and should I simply proceed as planned, letting her gush till she's done gushing... ?
Thank you!
Old Jun 2, 2010 | 05:19 PM
Doug's Avatar
If it's gushing THAT badly out of the filler tube go ahead and drain some coolant off and re-bleed. yeah, you don't wanna absolutely flood the engine with coolant.
Did get a good flow out of the bleeder before you clossed it off?
Old Jun 2, 2010 | 11:32 PM
michaem101's Avatar
Think I got it done. I topped and capped the main and bleeder and started her. Then I topped the side tube for a few minutes, then capped.....then as water came gushing through the bleeder, I put the screw back in.
It really sucks because I have that XJS CD ROM with all the info and it's not working on my XP computer. I'm certain it lists this quirky procedure in there somewhere...
hoodun
Feb 20, 2023 05:52 AM
Mac Allan
Jul 20, 2020 05:46 PM
Sonnyblack
Oct 4, 2015 05:42 PM
danke
Oct 3, 2015 09:31 PM
Markus
Sep 28, 2015 01:55 PM
