Radius arm bolt trouble
Old Jun 3, 2019 | 05:33 PM
Segfault's Avatar
Default Radius arm bolt trouble
I tried to remove it and it broke. Can anyone tell me if this is a special bolt or regular one? Despite the head of the bolt broke off the radius arm is still stuck in place. I suppose it should come off? I've never removed the radius arm before and have no clue how it is designed.
Edit: OK, the arm came off and now I understand its design. Does anyone know what size/thread is this bolt?
Old Jun 3, 2019 | 07:44 PM
Jagboi64's Avatar
It is a special bolt. The thread is 7/16-20 UNF, about 1.5" long. You could probably use a regular bolt. Use loctite on the threads, both to lock the bolt and to keep water out of the threads. The original bolt has a drilled head for lock wire.
Old May 16, 2026 | 08:37 AM
xjs_beginner's Avatar
- How did you remove the broken bolt? I have the same situation.
JimmyKat
Jul 27, 2025 07:01 AM
scottatl
Jul 21, 2025 07:55 PM
Ant Buck
Oct 7, 2023 07:31 AM
topanga
Jun 1, 2022 03:11 PM
Lannyl81
Oct 25, 2016 07:17 AM
