Real quick question
Old Feb 18, 2013 | 10:33 PM
buddyluv's Avatar
Default Real quick question
Did they really redesign the frnot brake caliper and shoe for the 94-95 xjs? What needed improvement? Bud
Old Feb 19, 2013 | 11:42 AM
Mkii250's Avatar
Maybe you mean the rear brakes, when they were relocated to the outboard position?
Old Feb 19, 2013 | 12:07 PM
Greg in France's Avatar
I have a feeling that the later models were fitted with fully floating calipers (ie only pistons one side, and the other side, on a slider system, is pulled in by the action of the piston).
These calipers are cheaper to make and more reliable with fewer pistons and seals.
Greg
Old Feb 19, 2013 | 10:56 PM
buddyluv's Avatar
Default Ah Ha
I thought so cause I saw some pads avertised on ebay and they looked (modern). The type where you must REMOVE the caliper to change them. As far as I'm concerned this is a step back from a simple change. Bud
Old Feb 19, 2013 | 11:45 PM
Doug's Avatar
If JDHT is to be beleived, the front brakes remained the same old 4-piston, fixed caliper design even after the rear brakes were moved outboard (and went to a floating caliper design)
Take a peek here and note the VIN range includes even the last models...
Brake Disc and Caliper-Front - Parts for XJS from (V)179737 to (V)226645 | Jaguar Classic Parts UK
Old Feb 22, 2013 | 12:45 AM
buddyluv's Avatar
Default misadvertisement
Then as usuall there's always somebody on ebay either with the wrong pictures or the wrong product SHHHEEEESSHH
Old Feb 22, 2013 | 08:26 AM
Doug's Avatar
Yeah, you gotta be careful and know exactly what you're looking for.
Sometimes you'll see the same catalog/parts listing error on several different webpages/vendor listings.
I suspect some of this goes back quite a few years when parts suppliers transitioned from paper catalogs to electronic catalogs and some stuff got lost in the translation....and never corrected unless the error concerned high volume parts.
Of course the odd parts listing errors have been around since....well...forever.
Shawn Svacha
Feb 6, 2022 04:53 PM
PMKimpton
Aug 3, 2019 08:22 PM
Mbourne
Sep 14, 2015 09:21 PM
1LowCat
Sep 14, 2015 07:51 PM
teacoff
Sep 10, 2015 08:25 AM
