Rear shock/tow link nut size
Old Jan 8, 2018 | 01:04 PM
sidescrollin's Avatar
Default Rear shock/tow link nut size
Does anyone know the size of the nut that holds onto the bottom of the rear shocks? I came up with part # NY607041J but this wasn't in a diagram, so I wasn't sure.
Typically searching part numbers eventually leads me to a site that will actually give specifications, but no dice this time. Thanks
Old Jan 8, 2018 | 02:24 PM
Greg in France's Avatar
These are the nuts holding the rod the shocks are attached to I think? For some unknown reason one end has an 11/16ths A/F nut and the other has a 5/8ths A/F. As I expect you already know, the rod can be withdrawn forwards only, as the bracer plate thingy on the rear end has a hole too small for the rod to be driven out rearwards. The actual threads each end of the rod are identical and have UNF threads.
Greg
Old Jan 8, 2018 | 03:04 PM
You aren't sure which is which though? I suppose a quick diameter measurement could determine which the bigger is.
The strap isn't attached on the XJ6 I just got, the nut (rearmost) is missing.
Old Jan 9, 2018 | 12:52 AM
THis is the one:
Part search results from David Manners Ltd - C87374
Greg
Old Jan 9, 2018 | 11:27 AM
7/16"?? Really? It looks way bigger than that at a glance.
Old Jan 9, 2018 | 02:12 PM
That refers to the thread size, not the nut A/F size.
sidescrollin
Nov 28, 2017 07:00 PM
cyber3d
Mar 14, 2016 04:54 PM
LeapingCat
Mark V - X 420G
Feb 22, 2014 12:39 PM
coastaljag98
Oct 27, 2012 08:16 PM
H20boy
General Tech Help
Oct 31, 2010 08:27 PM
