Rear wheel bearing change 1992 XJS
Old Apr 2, 2016 | 01:46 PM
NCJagman's Avatar
Default Rear wheel bearing change 1992 XJS
Hi all.
I'm loving this warmer weather so we can get out with the top down. While on a club drive this morning, I noticed a noise from (I think) the passenger side toward the rear of the car. It sounded like a rear wheel bearing was making the noise.
Does anyone on the site have experience of changing a rear wheel bearing on a 92 XJS convertible? Any guidance would be appreciated.
Thanks in advance.
Stephen
Old Apr 7, 2016 | 10:45 AM
NJ2003XJ8's Avatar
Must be similar to this:
Old Apr 15, 2016 | 12:40 AM
warrjon's Avatar
Before you go ahead find someone that will give you a collection of shims so you can get the right one (once you're finished return the unused ones), as the end float is set with shims and with new bearings you might need different thickness, I know I did on both sides
apachegogo
Mar 16, 2023 08:37 AM
CTRT
Dec 21, 2019 02:05 PM
Panhard
Mar 7, 2016 06:03 PM
brinny
Mar 7, 2016 04:45 PM
prodigy215
Mar 7, 2016 03:51 PM
