Rebuilding Rack and Pinion
Old May 20, 2014 | 02:37 PM
Eskr's Avatar
Default Rebuilding Rack and Pinion
Hello fellow XJSers,
Today I am coming to you with two questions. A little backstory first, though. Recently saw power steering fluid leaking on Morris, changed the power steering hoses as they were old, possibly leaking, and I had access due to the water pump being changed. The leaking stopped, up until about two weeks ago, when it power steering started leaking again. At first I thought it was the hoses, and that maybe I had bolted them in wrong (those fine threads, argh!). Nope, I removed one of the boots and lots of power steering fluid came out, so the rack seals have gone bad.
First question: How hard is it to rebuild the rack and pinion? XKs Unlimited has a kit to rebuild it. Taking it off is no problem, done it once already, and I'm pretty mechanically inclined (changed water pump, valve cover gaskets, etc.). I've never done a rack and pinion before, though, but I figure someone with a Master's degree should be able to figure it out, right?
Second question: assuming it sounds doable by me, how many of you would be interested in seeing me rebuild it? Maybe pictures, video, etc.?
Old May 20, 2014 | 06:19 PM
Bc xj's Avatar
Default My $500. POS XJS conv.
I would like to see that. I turned my steering wheel and heard a big clunk. I wasn't under power (engine doesn't run)and when I turned it again it clunked again. $cary $ound. I guess thats what I get for $500.
Old May 21, 2014 | 08:52 PM
icsamerica's Avatar
Rock Auto or some of the Jag specialty parts suppliers can have a rack to you in a few days ready to bolt in. I dont think its worth a DIY'er to build the rack on site. The special tools, techniques, and 100+$ worth of rebuild parts makes a 300$ ready to bolt in rack seem like a bargain.
NTL1991
XJ40 ( XJ81 )
May 1, 2017 07:54 AM
JTC3400
Sep 29, 2015 05:03 PM
Woznaldo
Sep 26, 2015 11:02 AM
SD96XJ6L
Sep 25, 2015 10:53 PM
