Recoding Remote Alarm Transmitters FAQ
Old Feb 17, 2010 | 07:45 PM
Default Recoding Remote Alarm Transmitters FAQ
Recoding Remote Alarm Transmitters - as posted by coventry west
We often get questions from customers on how to recode their remote alarm transmitters after replacing batteries. Below are the procedures for performing this recoding for 1990-1996 XJ6s. These procedures will only apply to Jaguar original equipment alarm systems, of course.
1990-92 XJ6 cars:
1. Record radio security code (if so equipped).
2. Disconnect negative battery terminal/cable.
3. Reconnect negative battery terminal/cable; "beeping" should be heard.
4. Press each transmitter so a total of 5 confirmations are heard.
5. Test operation. Enter radio code (if needed). Set clock.
1993-94 XJ6 cars:
1. Turn ignition key ON.
2. Turn security switch OFF (located in center console).
3. Turn ignition key OFF.
4. Turn security switch ON.
5. Cycle security system switch ON/OFF rapidly 4 times (within 5 seconds).
6. Press each transmitter so a total of 5 confirmations are heard.
1995-96 XJ6 cars:
1. Open trunk lid.
2. Open driver's door.
3. Turn ignition switch "ON" but do not start engine.
4. Rock valet switch (located in center console) 5 times; a single chirp and flash of the headlamps indicate the Security Locking Control Module has entered the "learning" mode.
5. Press the alarm/lock (larger) button of the first transmitter. This transmitter will be linked to position 1 of the seat/steering/mirror memory. A tone will confirm that the transmitter code was accepted. Note that the button must be pushed within 15 seconds or the module will exit the "learning" mode.
6. Rock valet switch once. Two short chirps will indicate the system is ready to accept a second transmitter. Press the arm/lock (larger) button of the second transmitter. Two tones will confirm the transmitter code was accepted.
7. Repeat steps 5 and 6 for up to a total of 5 transmitters. The second transmitter programmed will be linked to position 2; the third to position 3, and so forth. The number of confirmation chirps mentioned in step 6 will indicate the transmitter count (i.e. 3 chirps for third transmitter). Note that you must cycle through steps 5 and 6 five times regardless of the number of transmitters; if you have less than 5 transmitters just repeat using the last transmitter until 5 cycles have been finished.
8. Turn ignition off and close door and trunk. Test for proper operation of the seat/steering/mirror memories.
1996-06 XK8/R cars:
1. Insert ignition key into the ignition switch barrel, but do not turn it..
2. Hold the turn signal switch stalk in the "flash to pass" postion and turn the ignition on with the key (while holding the turn signal switch in "flash to pass").
3. Then repeatedly flash the lights with the turn signal stalk until a confirmation chirp is heard (usually five or six flashes).
4. After hearing the chirp, depress the button on the remote transmitter being programmed. If the remote was accepted, there will be another confirmation chirp.
5. Turn off the ignition and test the remote.
Old Sep 27, 2013 | 10:00 AM
Scoupe89's Avatar
good link
Old Sep 27, 2013 | 01:47 PM
Vee's Avatar
Vee
This is probably in the wrong section.
There is no reference to the XJS in these instructions. I can tell you that the instructions for the 95-96 XJ6 will not work for the XJS.
May as well delete this from the XJS forum and leave it in the XJ6 and XK8 forums.
Old Sep 27, 2013 | 02:28 PM
AllanG's Avatar
Won't work for 94 XJS either, no security switch in the console on US models.
You can install one though, the wiring is under the ski slope by the armrest.
Cheers,
Allan
Old Sep 27, 2013 | 05:33 PM
malc4d's Avatar
Does work for '91 - '92 xjs maybe '93
Old Sep 28, 2013 | 11:01 AM
Scoupe89's Avatar
Default It works!
This is how I reset my alarm and recoded in my '1992 XJS.
I had to try several times before it caught the signal.
The transmitter is very weak compared to new cars!
Old Nov 28, 2016 | 07:17 PM
afterburner1's Avatar
I take it, it was the '92 that worked?
Old Nov 1, 2022 | 02:18 AM
Terry007's Avatar
Great post but does it apply to a 1996 XJS ? I have disconnected the battery yet as soon as I reconnect it the alarm goes on again
Any suggestions would be gladly appreciated
Thank you
Old Nov 1, 2022 | 07:25 AM
Vee's Avatar
Vee
Thank you
There are no set of directions that hints at disconnecting the battery for a 1996 XJS as a solution.
For my 1996 XJS, the alarm should stop after 5 minutes...maybe it was 10, but not longer.
The FOB isn't turning it off?
Old Nov 2, 2022 | 10:16 AM
Terry007's Avatar
That you for the reply -
So , the alarm should stop within 5 or 10 minutes? Wow ! By then the SWAT team will be at my door, I live in a city !
no , the FOB is not stopping it -
Terry
Old Nov 2, 2022 | 10:37 AM
Keesh's Avatar
Get in the car, close de door, put the key in the ignition Turn ignition switch "ON" but do not start engine. Turn the key back, then "ON" again, repeat five times.
Old Nov 3, 2022 | 07:47 PM
Terry007's Avatar
Hi everyone
Update
I fixed it
I removed both battery terminals and voila !
Thank you for the messages.
Terry
JimC64
Jan 8, 2025 01:03 PM
JimC64
Mar 20, 2013 01:34 PM
JimC64
XJ40 ( XJ81 )
Feb 17, 2010 07:37 PM
daddylogan
XJ40 ( XJ81 )
Dec 14, 2009 04:27 PM
MJWebb
Mar 7, 2009 01:32 PM
