removing rear calipers
Old Jan 27, 2015 | 01:17 AM
  #41
texasscot's Avatar
Originally Posted by national87
The pad material is fine,I have the rearend out of car,on bench,just did new calipers & brake pads,go to install parking brake & they seem very tight on rotor,still tightens down on rotor but no ratchet action
I experienced am similar phenomenon. I disassembled the rear end and while i was there i rebuilt the handbrake calipers.
I didn't adjust the cable at the handle end and when I put it back together I found the cable was now too short to connect up to the calipers.
My solution was to pull the cable and sheath rapidly in and out of the body void and after a couple of minutes it suddenly became the right length.
My interpretation was that the sheath wasn't bedded properly in a hidden internal ferrule which effectively lengthened the sheath and shortened the cable.
This may not be the case but it worked for me!
Old Jan 27, 2015 | 08:40 AM
  #42
national87's Avatar
I got it I think,it does make ratchet sound when assembled complete on rotor,I wish there was a basic adjustment before going back on,I thought it was loose off rotor then I couldnt hook cable up so had to loosen up more,I hope its not too tight on rotor,kinda hard to tell now that its all in the cage up in the car,Dropping the rear is not a bad job at all,just little stuff like this takes so long because there is nothing out there on how to do the little stuff
FrickenJag
Jun 16, 2025 02:15 PM
dsnyder586
Dec 29, 2024 07:39 PM
philwarner
Sep 5, 2015 10:05 AM
davidladewig
Sep 3, 2015 06:32 PM
Joey T
Sep 3, 2015 05:31 PM
