replacement radiator
Old Jul 22, 2017 | 02:00 PM
Doug's Avatar
Originally Posted by VancouverXJ6
v12s - Home makes very very nice drop in aftermarket parts, twin fans and can even order with attached trans cooler to among other things.
I was going to do this and get a replacement aluminum radiator until I realized I could just run a gallon of metal rescue in the system
What is 'metal rescue'?
Old Jul 22, 2017 | 02:56 PM
VancouverXJ6's Avatar
A safe non acidic rust remover, I'll be pulling the coolant filter soon here will post pictures of the inside filter element after running this stuff for a week.
Old Jul 22, 2017 | 06:15 PM
v1rok's Avatar
V-XJ6,
So, you drained all the coolant and then ran 1 gallon of Metal Rescue in the car (instead of the coolant)?
I see how it can clean the rust in the radiator. But is it safe from other perspective (other parts coolant gets in contact with while circulating)?
Old Jul 22, 2017 | 07:05 PM
No just added the jug in with coolant and ran it for several days, the product is neutral and doesn't dissolve rubber or other materials I've put about 2000km on the car since then and only noted the substantially lower temps which were confirmed while it was at the shop earlier this week.
Forcedair1
Sep 8, 2025 01:57 PM
Jeh
XJ40 ( XJ81 )
Oct 13, 2015 09:23 PM
KarimPA
Sep 12, 2015 08:15 AM
obwoodie
Sep 3, 2015 07:45 PM
KarimPA
Sep 3, 2015 07:32 PM
