Replacing drive belts
Old Jan 16, 2011 | 02:30 AM
bigwiki's Avatar
Default Replacing drive belts
This is probably a dumb question from a XJS novice. I want to replace the AC/alternator/fan belts and the hood is blocking the front of the car. How do you guys do it? Please don't tell me I have to remove the hood...
Old Jan 16, 2011 | 09:58 AM
Roger95's Avatar
It's easy - takes an hour. And you don;t have to remove the hood.
First remove the air cleaner and ductwork so that you have clear access to the alternator. Working from top and bottom, loosen all of your adjusters. The AC belt comes off first and the alternator belt will fit up over the fan - very easy to do. Install your new belts, adjust tension and away you go.
Old Jan 16, 2011 | 12:22 PM
bigwiki's Avatar
Great. Thanks for the info Roger95.
BrentGardner
29
Dec 16, 2024 12:13 AM
RaceDiagnostics
Dec 11, 2015 10:12 AM
Fraser Mitchell
Oct 1, 2015 04:06 AM
Will P
Aug 27, 2015 06:52 PM
dpappyp
Aug 27, 2015 06:31 AM
