Rescue's Official Build Thread - 88 XJS V12 Oct 12 2019
Old Sep 10, 2022 | 05:25 PM
  #1421
Rescue119's Avatar
So the xjs he took it of was originally a California car. He took it off 15 years ago and he said it was a mid 80s xjs.
Also the spoiler has the hole for the antenna roughed in. What I mean is the hole detent is there but it's not open.
Old Sep 10, 2022 | 09:03 PM
  #1422
Mguar's Avatar
The best way to save that would be to do a rude and crude patch job. Than use those parts as patterns to make fresh molds.
It’s not hard. Nor should it be messy or terribly expensive. With experiance you should be able to repair a piece and make a mold every day until the whole set is duplicated. Use cheap chopped Matt to make the mold. However for the actual parts use cloth or get fancy and use Kevlar/carbon fiber. ( that will more than double the costs but dramatically add to the strength and durability ).
There are plenty of U tube video’s showing how. Or you could find a local to either show you how or simply do it for you.
Notice I said local. Shipping parts even light fiberglass parts around is expensive, not because of weight but because of the boxing requirement.
Old Sep 10, 2022 | 09:11 PM
  #1423
89 Jacobra's Avatar
Active Streak: 30 Days
Being Fiberglass it can definitely be repaired as it was simply a resin and glass matt, or strands. the "Mold" would be nice as that makes it easier, to get things back to what they were, but it is not absolutely necessary. Use cardboard to fill in, and create the contour for the missing pieces, to the general shape, and then glass over it. If it's not in a critical or visible area you can leave the cardboard in place. Looks to be a fairly nice design. Hope it helps.
Jack
Old Sep 11, 2022 | 01:33 AM
  #1424
Mguar's Avatar
Yes you can repair it that way but it will always be a weaker area.
For cosmetic reasons only you can probably get by, but to retain a percentage of strength, you will need to spread the repair out because the joint will not be very strong.
Access to the back side will allow the added mass required to regain a percentage of strength to be hidden.
If you’ve ever experienced a major body failure at the speed Jaguars are capable of you’ll understand my concern.
Old Sep 11, 2022 | 05:47 PM
  #1425
Rescue119's Avatar
I had some reinforcement tape I use to use for r/c bodies so taped the broken piece up to the rest of the rear.
Here's what it would look like together and in the right orientation
Old Sep 12, 2022 | 04:09 AM
  #1426
Shaneb's Avatar
Looks like the condition I got an xjs lister body kit in many years ago off a wrecked car, took a fair bit of bit to patch up. Pics from 2005 and of recent, generally most days still like the look of the kit.
Old Sep 12, 2022 | 08:32 AM
  #1427
Rescue119's Avatar
Awesome. Thanks for the pics. I don't have the front piece though.
Old Sep 12, 2022 | 08:34 AM
  #1428
Rescue119's Avatar
If you have any pictures of how its mounted please post them. Most of the holes are busted. It will be a next spring project
Old Sep 12, 2022 | 09:52 AM
  #1429
ptjs1's Avatar
Rescue,
I stand corrected! Now that I see that the bumper was upside down in the first pic, it could be from a Lister kit. The Hyper rear bumper is also similar, but I recall had cutouts for rear fogs next to the exhaust pipes.
Paul
Old Sep 12, 2022 | 03:47 PM
  #1430
Rescue119's Avatar
Originally Posted by ptjs1
Rescue,
Paul
i think those 2 round holes are for where the rear bumper supports pass through looking at other pictures i found online..
Old Sep 12, 2022 | 08:57 PM
  #1431
Rescue119's Avatar
Do you have a pic of the finished rear? Straight on
Old Sep 13, 2022 | 12:14 AM
  #1432
Greg in France's Avatar
Correct, they are.
Old Sep 13, 2022 | 02:41 PM
  #1433
Rescue119's Avatar
Correct, they are.
you will also note the fade paint in that area where the inside of the bumper would have been slightly rubbing during its time mounted
Old Sep 13, 2022 | 09:29 PM
  #1434
Rescue119's Avatar
Was the orginal rear bumper a 3 piece? Cause it looks like someone tried to make it a one piece at some point
Old Sep 16, 2022 | 11:50 AM
  #1435
Rescue119's Avatar
my quickjack showed up this morning so hopefully i can get that together this weekend. Im away sunday to sunday though.
Old Sep 16, 2022 | 09:29 PM
  #1436
Rescue119's Avatar
Pic of boxes. I got all the accessories as well so I can use it for multiple vehicle types etc and it's the one rated for 7000lbs
I got this light from quickjack as well.
It's pretty sweet and bright. Different ways to mount it as well
Old Sep 16, 2022 | 09:44 PM
  #1437
89 Jacobra's Avatar
That Lite Stix looks pretty Cool. I think I've seen it by other manufactures as well, I didn't know Bend Pak even made them. Looks like a damn nice light.
Jack
Old Sep 17, 2022 | 01:44 AM
  #1438
Shaneb's Avatar
Rear skirt is three piece so you must be joined, attached are some pics from rear. If you want to know more on how it is fastened let me know
Old Sep 18, 2022 | 09:55 PM
  #1439
Rescue119's Avatar
Awesome! Thank you so much.
I plan on shaving the rear bumper off when I get to yhe body phase of my project. I think ill make it a one piece though.
How come u have red lights in your rear bumper?
Old Sep 19, 2022 | 03:28 AM
  #1440
ptjs1's Avatar
Most markets have the lights in the bumper. Perhaps only North America didn't because of the paranoia over crash protection?
Paul
