Rolling Road V12
Old Aug 10, 2015 | 04:18 AM
melhookv12's Avatar
Just found my old rolling road print outs. Thought I'd share. Think I'm going to have to rebuild this.
518 ft/LBS
408 bhp.
Bhp very low but the engine was very tired. Hoping to get 500 bhp. But I'm happy with the torque figure.
Old Aug 10, 2015 | 07:57 AM
ronbros's Avatar
nice numbers, over 400 HP, and great torque, gotta be a good street car!
what mods have you done???
Old Aug 10, 2015 | 08:52 AM
Katoh's Avatar
Yep! spill the beens, what has being done here, 500HP?
Old Aug 10, 2015 | 05:11 PM
melhookv12's Avatar
It's a genuine lister 7.0 litre. Was running on webbers at the time.
Going to put it on injection. The rolling road guy said the engine was ' tired ' .
When it was stripped the engine man said it was built very badly.
So hopefully get a few more horses.
Old Aug 10, 2015 | 06:16 PM
Katoh's Avatar
Say no more!
Old Aug 12, 2015 | 01:44 AM
Flint Ironstag's Avatar
Heh - I think most of us would be thrilled to produce those numbers. What should a healthy Lister look like?
Old Aug 12, 2015 | 03:48 AM
melhookv12's Avatar
I would say somewhere nearer 500bhp. But it's the torque that matters.
The engine in this car was originally twin super charged. We purchased it without those. The body shell was rotten so we took all the goodies off.
Cosworth don't make the pistons any more so will have to look else where.
Any one recommend a good piston supplier in the UK?
Old Aug 12, 2015 | 10:43 PM
Broken_Spanners's Avatar
Awesome numbers for a "tired" engine..
What compression ratio are you running being formerly blown? It is very interesting to see how fast and dramatic your torque curve fell off, but it would be interesting to know how many pounds of boost the former setup was running and carbs mit twin chargers would personally scare me to death in the whole piston melt area.
Anyways, I have had great luck with JE Pistons over the pond and have subjected the same to some huge numbers (650+ crank on turbocharged stuff) without fail. You may also want to consider Autoverde, Carillo, or Seinz rods. However, with everything needing to be custom, time to machine and cost might get silly. Are you dry sumped currently?
The C-Type recreation you see in my signature is a 3.4 XK six punched to 3.9, 11:1 comp, triple 45 DCOE's, knifed crank, polished and lightened rotating assembly and all sorts of other bits head side, and I'm at roughly 345 crank. But, being that the car only weighs 1,750lbs, it's a bit of a death trap.. ;-)
I tell you all that nonsense as you can easily get help Stateside as well, but understand if you want bits closer to bore match and such, in which case I'd contact KWE..
Cheers,
Jeff
Old Aug 18, 2015 | 02:21 PM
melhookv12's Avatar
Broken Spanners, we had it cc'd and its running 10.5-1 compression.
It was on fuel injection when super charged.
I have seen JE pistons. What i need is someone to just match the pistons that we already have. We might up the comp ratio a little bit but no real need to go crazy.
We sold the webbers on as it was hard finding someone to tune them, and evidently the guy who tuned it for us either let it run very lean or had the timing to far advanced as we suffered head gasket failure and detonation. A expensive lesson !
Zimbomac
Apr 7, 2019 10:56 AM
damienedwards
May 2, 2016 04:51 AM
Ozzy_UK
Sep 24, 2015 08:44 PM
Oracle
Sep 24, 2015 08:35 PM
somoflange
Sep 16, 2015 10:16 AM
