Security system antenna remote fob
Old Oct 16, 2019 | 02:54 PM
kansanbrit's Avatar
Default Security system antenna remote fob
Does anybody know where the antenna for the remote key fob is located on a 1994 XJS 4.0. I have found the wire where it connects to the security module in front of the right rear light but I am unable to find any information on the antenna itself. Trying to improve the range. Thanks.
Old Oct 16, 2019 | 06:10 PM
ptjs1's Avatar
kansanbrit,
On RHD cars it was at the base of the b-post. Something makes me think it's probably in the same place on LHD cars.
Paul
Old Oct 16, 2019 | 10:00 PM
ralphwg's Avatar
Try holding the key FOB to your forehead. That makes your body an antenna and makes for a significant increase in range. I know this works on my 2013 XKR. Will try it on my XJS tomorrow.
Old Oct 17, 2019 | 07:47 AM
malc4d's Avatar
There is a way of slightly improving the range by soldering a small piece of wire inside the remote. It was detailed here I believe how a few years ago. I will look for it. Also l can confirm the fob to the forehead procedure does work.
Old Oct 18, 2019 | 09:56 PM
kansanbrit's Avatar
Default Normal range
Thanks guys. Would anybody like to comment on what would be considered a 'normal' range for the xjs remote?
Old Oct 20, 2019 | 05:03 AM
malc4d's Avatar
2 to 4 feet. works better on the right side. Forehead method improves it a bit further.
Old Oct 20, 2019 | 07:02 PM
ralphwg's Avatar
On mine with fresh batteries it is more like 5-7 feet.
Old Nov 6, 2019 | 07:03 PM
Rick25's Avatar
My '93 and also '92 has the antenna coiled up behind the right hand rear quarter lower trim pad assembly. It will be coiled up in the wiring harness.
Just pulled this out of my Jag update booklet.
Old Nov 7, 2019 | 09:23 AM
kansanbrit's Avatar
Thanks for the info Rick. I actually found a tech sheet that says the antennas were supposed to be uncoiled and attached vertically to the panel during production but many weren't so that makes sense. I need to take a look at mine.
DJ-Roy
Nov 7, 2019 09:44 AM
Doug Dooren
Jun 30, 2014 04:30 PM
gbmtkj
Nov 21, 2013 10:51 AM
jagsami
Jan 7, 2008 06:53 PM
