Steering fluid question
Old Mar 12, 2016 | 03:00 PM
JayCee's Avatar
Default Steering fluid question
I tried to check the power steering fluid level today. Am I missing something or do I have to remove the radiator hose? I was able to unscrew the cap but it can not be pulled out because the hose is right on top of it. Hard to believe it was designed like this.
...Jimmy
Old Mar 12, 2016 | 04:43 PM
jal1234's Avatar
Just did this yesterday. I just shoved the hose out of the way while removing the cap. There is enough flex in the hose to do it. Cold engine, of course.
Old Mar 12, 2016 | 07:27 PM
JayCee's Avatar
I'll try again tomorrow...seemed pretty tight. Also removing the air cleaner seems to help.
Thanks...jimmy
Old Mar 13, 2016 | 05:40 AM
Sense of humour is a must.
Some I have had to attack over the years, have had the wrong length p/steer belt fitted, so the angle of the dangle of that filler spout is blocked by that hose.
HOWEVER, to change that belt requires a special talent, and HEAPS of alcohol.
Old Mar 13, 2016 | 07:24 AM
Steve M's Avatar
Yeah, but wait until you try and top up the reservoir, then the fun really begins.
The best way I have found is a biggish syringe, the sort that vets use.
That's vetinarians, not veterans.
Obviously.
Old Mar 13, 2016 | 08:04 AM
Steve,
Its that V12 experience.
It is such a "special" thing, and very few understand it, and even less tolerate it.
Old Mar 13, 2016 | 10:32 AM
NathanDD6's Avatar
Hit the nail on the head there Grant, which reminds me I should check my fluid level.
Old Mar 13, 2016 | 11:18 AM
JayCee's Avatar
Well...I tried again this morning. The hose won't move because the cap is very close to the end of the radiator hose and only about 1/2" from it. I plan on changing out the thermostats soon, so I'll check the fluid and replace radiator hose while I'm at it. Check out the pic, taken from under the filter housing. Gotta love these smart phones!
Old Mar 13, 2016 | 01:35 PM
Stargazer XJS's Avatar
Here I thought I'd be able to swoop in and do some good for a change, but judging by that photo, your dangle angle is more mangled than mine was. All I had to do to free the cap was loosen the hose clamp and give it a bit of a twist. Then again, I've got an '88 and I keep forgetting the 6.0L is a horse of a different color.
Grant's belt idea, with or without the prescribed heaps of alcohol, might be your best bet.
Good to see another RE rider, by the way.
Old Mar 13, 2016 | 02:17 PM
JagCad's Avatar
Never tried it on that situatin. but, a plumbrer's basin wrtench for the cap and a a turkey baster to squirt in fluid. Best not returned to the MRS' pantry, just let it disappear ands bvecome a garage tool.
Carl
Old Mar 13, 2016 | 03:16 PM
JayCee's Avatar
[QUOTE=
Good to see another RE rider, by the way.[/QUOTE]
This Jag is the only vehicle that requires more maintenance than an RE!
So, why do I love both of them? Ever thought about the fact that the RE cylinder size is the same as one of the V12's.
Cheers...Jimmy
Old Mar 13, 2016 | 07:55 PM
OOPS.
My notes state a 13A1080 as the p/steer belt for the 6ltr.
Maybe the old belt still has numbers available, and then a simple cross reference will establish wrong or right belt actaully on the car.
The 5.3 states a 13A1090 belt, so 10mm longer.
MAYBE???, someone put the "1090" on it, not realising its a 6ltr,whereas the "1080" would have that cap just inside that hose and slightly easier to get at.
Old Mar 26, 2016 | 12:35 PM
JayCee's Avatar
Grant...now that I developed the steering rack leak...this pump got a little higher on the priority list. (I think the Jag did it on purpose).
I just spent about 2 hours getting the old belt off. It is so short that with the pump adjusted all the way in, it was still not loose enough to get off. I ended up cutting it off. The belt was a 13A1075. I know the 1075 belt can't be correct because the adjuster still had about 2.5 inches of threads thread left for tightening.
The new belt needs to be at least 1 inch (25mm) longer in order for the pump to be in a position (outside the hose) that I might be able to remove the cap for checking fluid level and filling. I am going to the parts store and see what they have. Then I can start on the steering rack (jump for joy!)
...Jimmy
Old Mar 26, 2016 | 06:55 PM
Done desl.
Gates and Dayco use the number system you need, so, based on your words, I would be getting a 13A1090, and that will still give adjustments.
Once again wrong stuff from an idiot spanner man, and the Jag gets blamed for it, bugga.
Old Mar 27, 2016 | 08:03 AM
malc4d's Avatar
Jag classic parts shows eac1323 for the 6.0 steering belt
Old Mar 27, 2016 | 08:28 AM
JayCee's Avatar
I installed a Duralast 13A 1120mm. It fit perfectly. The tensioner is right in the middle of it's travel and the pump is now accessible. (see pic) I looked at several websites and they all have the recommended size at 1075 to 1090. I'm not sure why my car would be different, but the 1120mm is the correct size.
...Jimmy
reichstall
Mar 14, 2016 07:43 PM
jmarkitell
Mar 12, 2016 04:59 AM
Jason Souhrada
Mar 11, 2016 01:39 AM
Doug
Mar 8, 2016 08:01 AM
m.w.l.
Mar 7, 2016 03:39 PM
