( Update due to editing bug in original post ).
Fitting switch covers with less frustration. Begin by buying better screws in advance. The upper cover is fitted first, held with 2 screws at the front, and one screw further back, to brackets around the steering column. Jaguar used short 8-32 cheese ( slotted ) head screws which are not easy to put back in. Phillips or pozi head would be easier. So 1 of those screws was missing on my cover, probably a typical result if anyone has worked in that area before. The 2 front screws are a pain to firstly line up the screw holes and then to actually try and fit the screws. A small telescopic inspection mirror helps. I bought longer 8-32 X 1&½ long phil head screws and used locknuts to form what is in effect a longer shoulder screw for the 2 front screws. Much easier to fit them back in. The lower cover fits to the upper cover at the rear with 2 cheese head 8-32 X 1&¼ screws. Once again phil or pozi head makes life easier. I could only find 1&¼ long screws so had to add washers+nut to get the correct effective length. There is also a short cheese head ST screw used at the front securing the lower cover to the steering column bracket, and that is easy to fit.
Wiper & indicator switch bracket
Those 2 difficult holes from below.
[img alt="ST screws for horn push on left.
Then 2 Jag screws, then better version. On right the shoulder screw."]https://cimg0.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1250/cover_screws_504daa5ca3be99a84502e71b42a7722896174 aea.jpg[/img] ST screws for horn push on left. Then 2 Jag screws, then better version. On right the shoulder screw.
