Tachometer removal
Old Sep 15, 2011 | 09:22 AM
Dan Silliman's Avatar
Default Tachometer removal
1991 XJ-S- After removing the instrument cluster from the dash, is there any problem removing and replacing the tach from the cluster?
Old Sep 15, 2011 | 11:15 AM
Doug's Avatar
No, no "problem", per se. You'll have to partially disassemble the cluster....slightly delicate work but not difficult. Be careful of the flexible printed circuit....it'll be a bit fragile from age.
this is a god opportunity to clean all the circuit contacts, clean the cluster lens, replace bulbs if needed, and add a redundant ground.
Old Sep 16, 2011 | 08:06 AM
Doug- Thanks for your help in removing the tach. I've had the cluster out replacing the bulbs, but I was a bit nervous about replacing the tach. Have a great day! Dan
dsnyder586
Dec 29, 2024 07:39 PM
aholbro1
Dec 29, 2024 06:46 PM
mrsimpson
Sep 15, 2015 01:10 PM
Rablaw1971
Sep 11, 2015 10:24 PM
1964Daimler
Sep 9, 2015 11:28 AM
