temperature switch 1984 v12
Old Apr 7, 2018 | 10:17 AM
rgp's Avatar
rgp
Default temperature switch 1984 v12
on the temp switch at the rear of the r.h. water rail. EAC3762
not the gauge sender at the front.
Is one of the wires an earth as one is black and the other looks like black with a grey tracer, if one is a earth it would mean I could earth somewhere else and not cut into the harness
Old Apr 7, 2018 | 10:56 AM
Greg in France's Avatar
What are you trying to do with it Rex? If you want to disable the 15 minute enrichment timer, you just disconnect the switch and tie off and insulate the wires.
Old Apr 7, 2018 | 11:28 AM
rgp's Avatar
rgp
just want know if its an earth that's snapped off in the harness if it is I can run in another one and wont have to cut up the harness.,
its black and if it is does it go under the throttle vacuum control switch?
Old Apr 7, 2018 | 11:33 AM
Rex
Black is always earth on the XJS. One way to test it would be to earth it, start the car cold and then un-earth it while running. It it is working OK, then you will hear the engine note change as the enrichment stops (the equivalent of the switch switching off when hot).
Old Oct 21, 2019 | 03:54 PM
scottpeterd's Avatar
Where do I find the fabled 15 minute enrichment timer so I can try disabling it?
I assume it should be on one of the water manifolds with just 2 wires running to it
Old Oct 22, 2019 | 12:39 AM
It is on the A bank rear water manifold. It is to the rear of the outlet to the heater and has two wires to it. Just remove the wires and tape them off. If you have a USA spec car it does not have the 15 minute timer.
Old Oct 22, 2019 | 08:56 AM
That would explain why I have not been able to find it
charlie2
Jun 30, 2017 03:28 AM
Roger Mabry
Aug 31, 2013 11:04 AM
xjstrader
Feb 21, 2013 04:27 AM
r3ml
Nov 22, 2012 06:55 PM
Meatpotatoes
Jan 16, 2012 08:30 PM
