Is there a way to (Deliberately) Trip the Fuel Pump Cut Out
Old Aug 30, 2017 | 11:55 AM
orangeblossom's Avatar
Default Is there a way to (Deliberately) Trip the Fuel Pump Cut Out
Hi Guys
Since I am properly Paranoid about one of my XJS's being Stolen, I was wondering if it were possible to (Deliberately) Trip The Fuel Pump Cut Out.
Without the need of turning the Car upside down
Preferably somewhere remote from where its positioned in the Car.
As an extra Security device, is there a way of Tripping the Cut Out deliberately?
Old Aug 30, 2017 | 12:06 PM
icsamerica's Avatar
Just give it a jolt with your hand. It trips easily. You may want to remove the plastic cover before wacking it. You can re-afix it using 3M dual lock so it's easily removable and replaceable.
Old Aug 30, 2017 | 12:07 PM
Daim's Avatar
Why not simply whip a fuse out? Or better the starter relay in the engine bay when left parked for a while...
Old Aug 30, 2017 | 12:53 PM
Hi Daim
Cheers!
Which Fuse would you suggest?
Old Aug 30, 2017 | 12:56 PM
Mac Allan's Avatar
I seem to recall that you had installed a battery cut switch on one of your cars, why not use it?
Then the cut out switch is in the locked boot with some protection. You would lose the alleged benefit of the car alarm, but they don't actually stop theft and are universally ignored by bystanders.
Audible car alarms do not have a significant effect on car theft.
The insurance data are unequivocal. In 1997, the non-profit Highway Loss Data Institute (HLDI) surveyed insurance-claims data from 73 million vehicles, to see which devices could prevent theft. Looking at cars from many different model years, across the country, the study concludes that cars with alarms "show no overall reduction in theft losses" compared to cars without alarms.
Paper: "Alarmingly Useless, The Case for Banning Car Alarms, in New York City", by Aaron Friedman, Aaron Naparstek & Mateo Taussig-Rubbo
Old Aug 30, 2017 | 01:22 PM
Hi Mac
I use the Battery Cut out switch all the time, even when I park for a few minutes.
Car Discarnect
One of the Best Pieces of Kit I've ever bought.
Just undo the Green Wheel a couple of turns to disconnect the Battery
Old Aug 30, 2017 | 04:02 PM
Jagsandmgs's Avatar
If it's the early version, just take off the black plastic clip on cover and pull the plunger on top up. The later kind has a rubber cover over the plunger so you can't pull it up.
I once tripped it on a New Hampshire road loaded with frost heaves.
Old Aug 30, 2017 | 04:14 PM
afterburner1's Avatar
You could put an on/off switch on the UR line between the fuel pump relay and fuel pump. (looked at 1993 electrics)
Old Aug 30, 2017 | 04:33 PM
Hi Afterburner
Cheers!
That sounds like a better idea than mine, so well worth looking into, as if I start Tripping the Cut Out.
Then it might start doing it when I don't want it to.
Old Aug 30, 2017 | 11:13 PM
Daim's Avatar
Personally I don't like it when batteries are connected, disconnected, connected, ... That will kill the electronics sometime. I'vergessen managed to kill a Bosch LH2.4 Jetronic ECU like that...
Old Aug 31, 2017 | 12:28 AM
Hi Daim
I've been using the Battery Isolator Switch for over 3 years without any problems, surely nothing can happen until the Ignition is turned on.
Or am I missing something here?
Old Aug 31, 2017 | 11:49 AM
leo newbiggin's Avatar
i wouldnt mess with the trip thingy. it may get a "taste" for tripping. ive got a couple of inline spade terminals from the fuel pump in the boot near the battery. When i was having the battery changed at the local exhaust centre when i first got the car, the plum that was fitting it pulled one of the terms, not fully out but enough to make me spend half an hour trying to get the bloody thing started again. just pull a terminal out, a thief will soon give up if he cant start it and zoom off quickly.
Old Aug 31, 2017 | 01:15 PM
sidescrollin's Avatar
Gosh you guys are all talking about pulling fuse panels and getting into the trunk everytime you get in and out of the car.
I think he is dead on with using the fuel cutout switch. All you have to do it grab it and pull it up (it clearly shows red). Thats easy to do and most people would never know to mess with it if they tried to steal the car.
Man, I leave mine unlocked 95% of the time. Don't even stress about it.
Old Aug 31, 2017 | 05:25 PM
warrjon's Avatar
You could add a switch under the dash in series with the inertia switch simply flick it off when you get out and the car will not start.
Old Aug 31, 2017 | 05:48 PM
That's not a bad idea leo, I'll have a look at the set up.
Old Aug 31, 2017 | 05:54 PM
Hi sidescrollin
I've gone off messing around with the Cut Out Switch, like leo says, the Car could get a bit of a taste for it and start tripping out on its own, if the mechanism starts to get worn.
You wouldn't leave anything laying around down my way, it would be Gone in 60 Seconds.
Old Aug 31, 2017 | 05:57 PM
Hi Warrjon
I'm liking that a lot!
Would it just cut the Power or trip the switch or both?
Old Sep 1, 2017 | 01:49 AM
Greg in France's Avatar
Originally Posted by orangeblossom
Hi Warrjon
It would prevent the fuel pump circuit getting power at all. The switch would not "know" about it and would not trip. Great plan and quite straightforward to do. Pull the switch cover, drop the shin trim and maybe the side trim on the A post bottom, and the wires will be easily accessed.
Old Sep 1, 2017 | 02:58 AM
Hi Greg
Cheers!
That sounds like a Plan! and I could hide the switch in the glove box.
Old Sep 1, 2017 | 05:56 PM
warrjon's Avatar
Yep Greg is right, the inertia switch will not trip as it is a mechanical trip switch.
