Are These Headlight Wiper/Washers Parked In The Right Place? XJS V12
Old May 1, 2015 | 01:35 PM
orangeblossom's Avatar
Default Are These Headlight Wiper/Washers Parked In The Right Place? XJS V12
Are these Headlight Wiper/Washers Parked in the right place.
What you see in the Photo, is exactly how I found them, as while I'm still doing the ABS, I haven't had the chance to power them up.
But both headlight Wipers are Parked underneath what appears to be a couple of 'Rubber Bump Stops'
It's exactly the same on both sides of the Car and neither one of the Wipers or the Wiper arms they are on, seems to want to be Parked on Top of these 'Bump Stops'
So basically that is my Question:
Should the Headlight Wiper Arms and Blades, Park themselves 'On Top of' or 'Underneath' these Rubber Bump Stops?
(What looks like Rust is in fact Grease to prevent Rust while being laid up)
Old May 1, 2015 | 02:05 PM
Daim's Avatar
Nope. They should sit on the bump stops... I can take a pic tomorrow if you wish
Old May 1, 2015 | 03:15 PM
Hi Daim
Thanks, a pic would be very handy but since I've never adjusted them, I am wondering why they are where they are.
Old May 1, 2015 | 04:07 PM
Safari's Avatar
Originally Posted by orangeblossom
Hi Daim
Most likely a previous owner pulled them off and was not careful to put them back in the correct position.
I had a similar issue with the windshield wipers on my '90. I had to remove the arms and rotate them to the correct splines so the wipers would park in the correct position. Now my wipers look nice and sweep in the proper arc.
Mark
Old May 1, 2015 | 04:52 PM
Mark
Cheers Mark
That's what I started thinking!
but I really wanted to get a second opinion.
Old Apr 2, 2018 | 12:07 AM
Greg McDonald's Avatar
Mark
I know this is an old post but does anyone know how to remove the arms as described above?
My wipers are parking in the centre of the headlight Instead on the stops at the botto m of the light.
Old Apr 2, 2018 | 12:57 AM
Greg in France's Avatar
Pull back he spindle covers. One of them has a small nut; undo it. Then, and careful here, get a pair of pliers and place one jaw under the arm where it goes round the spindle and the other ON the spindle. A firm grip and the arm pops off with no damage to the spindle and motor bearing.
Old Apr 2, 2018 | 04:05 AM
Thanks for the quick response Greg.
that was pretty easy. Go them from this
To this
In just a few minutes.
Before adjusting them they weren't actually working and they continue to not work so that will be the next job. At least they look ok now.
interestingly neither wiper motor or headlamp washer works so I'm thinking something electrical in the switch mechanism rather than the individual component.
happy for any advice on that too.
Greg
Old Apr 2, 2018 | 05:42 AM
try them with the headlights on! they only work when the headlights are on.
Looking good now, so well done.
Old Apr 2, 2018 | 06:01 AM
Yeah, that's how I tried them, with the headlights on. Not working.
not much rain here in my part of Australia at the moment and I tend not to drive in the rain and even if I did wipers seem to be more for sleet and snow which we get zero of so no practical reason to get them working other than addressing my compulsion to fix things that don't work.
at least they look better now.
Old Apr 6, 2018 | 03:37 AM
rgp's Avatar
rgp
check the connectors either side by the radiator, whenever mine pack up its dirty plugs and sockets that stop them. its one of these check colours but I think its the black and white one
Attached Thumbnails Are These Headlight Wiper/Washers Parked In The Right Place? XJS V12-100_7670.jpg
Old Apr 6, 2018 | 05:21 AM
I'll let you know how I get on
Rlover
Mar 30, 2016 10:04 PM
sklimii
Sep 5, 2015 06:04 AM
laserguy
Sep 3, 2015 02:02 PM
d a
Sep 3, 2015 02:34 AM
XJsc-guy
Sep 2, 2015 11:43 AM
