Throttle Vacuum Switch - 84 XJS
Old Apr 27, 2016 | 05:00 AM
darrhel's Avatar
Default Throttle Vacuum Switch - 84 XJS
Greeting,
i was advised by the local Jag supplier here in West Oz, Roadbend, that the Throttle Vacuum switch is no longer available.
Mine is working ok, even though i have had to solder up the terminals a coupla times.....
Leaves the question of where to get one from if i do need a replacement unit....?....or is there an alternative unit out there.....?
attached a pic of the one of the mistress.
Regards
Darren
Old Apr 27, 2016 | 05:59 AM
Darren,
That is the very old style switch, used on the PreHE and He in the early builds.
It was replaced by what we all call the Blue/White throttle switch. I have the part number somewhere, and I will find it as soon as I can and let you know.
Old Apr 27, 2016 | 08:31 AM
user 652867429824's Avatar
here's the part number and name according to the parts catalog. JLM473 throttle valve. this place has a used one but a bit pricey IMO
http://jaguar-parts.jagbits.com/throttle-control
Last edited by user 652867429824; Apr 27, 2016 at 08:39 AM. Reason: to add more info
Old May 1, 2016 | 05:26 AM
Darren,
I have hit a brick wall.
I cannot find the part number for the later Blue/White valve.
I found a valve in one of the boxes of stuff, but no package with a part number, and it does not hold vacuam.
I will keep looking, I must have it somewhere.
Old May 1, 2016 | 08:05 AM
Greg in France's Avatar
Happy to oblige, Chief:
EAC4371
http://www.jaguarclassicparts.com/uk...itch-5-3-litre
Darren: No 1 on the diagram:
Norman Motors have ONE. 70 UKp though!
EAC4371 THROTTLE CONT SWITCH
Greg
Old May 1, 2016 | 08:42 AM
Thanks Greg,
Thats the PreHE and early HE unit that is now coming up NLA, so maybe old stock, and at that price they will live with it.
I will contact my guys in the morning with that part number, and see if it supercedes to the Blue/White unit, hope so.
Old May 1, 2016 | 08:55 AM
Just to confirm I was not going more carzy that normal, I found a snap of that Blue/White valve on my car.
Old May 1, 2016 | 11:48 AM
Darren,
Grant
On the JCP site as linked, there is a huge list of the things, when you expand the part number reference 1, for various different markets. Maybe your later one is in the list somewhere? The above is the UK one listed for cars up to the facelifts.
Greg
Old Aug 31, 2016 | 11:20 PM
darrhel's Avatar
Greetings
tested the vac on the throttle switch the other day and its switching at 20mm hg....is this the correct setting...?
found something similar on the net, looks like it may do the job, mine has not given up the ghost yet...!....other listings for this come up as a Harley Davidson part...?
https://www.amazon.com/Standard-Prod...988850&sr=1-23
all good
Darren
Old Sep 1, 2016 | 06:47 AM
Originally Posted by darrhel
Greetings
all good
Darren
That 20mm sounds around the mark.
Here is the snap I found of this Blue/White valve, BUT, I cannot find the part number.
34by151
May 6, 2024 12:20 PM
ianf3
Apr 17, 2016 12:26 PM
kenatofc
Apr 6, 2016 11:26 AM
dannio636
Apr 6, 2016 10:59 AM
Merovean
Mar 31, 2016 04:29 AM
