Tps on 89 jaguar xjs marelli ign.
Old Jun 17, 2018 | 07:26 PM
Buzzaw's Avatar
Default Tps on 89 jaguar xjs marelli ign.
doe the red wire on tps need to be connected? car warms up runs good then starts running rough like not getting fuel wont accelerate. then i disconnrct red wire (wiper)and runs great
Old Jun 17, 2018 | 09:20 PM
Doug's Avatar
The TPS helps adjust fuel metering as the throttle is opened. Not sure how much influence it has during steady-state conditions.
Yours apparently has a fault that is cocking up fuel metering; disconnecting the wire removes troublesome signal.
I wouldn't want to go indefinitely without TPS input the system probably defaults to a preset and possible less-than-optimal fueling map without it.
Let's hear what others have to say
Old Jun 18, 2018 | 02:00 AM
warrjon's Avatar
Red wire is the signal back to the ECU, so I agree with Doug sounds like TPS is playing up.
Disconnect the TPS plug switch your multimeter to Ohms and meter green to red then move the throttle capstan slowly the ohms should go between about 5000 and 400 ohms smoothly with no jumping around.
It is important the TPS connector is unplugged and you move the capstan slowly so the DVM can keep up.
Old Jun 18, 2018 | 01:46 PM
Buzzaw's Avatar
Default Tps
Thanks for help. The tps is fairly new. Must be with the wiring but all looked to be good at computer.
Old Jun 18, 2018 | 04:31 PM
motorcarman's Avatar
Maybe the TPS is Out Of Adjustment????
There are slots to adjust.
More info on the replacement TPS.
bob
File Type: pdf
Old Jun 18, 2018 | 05:26 PM
Buzzaw's Avatar
I adjusted the tps when I installed. I just started working on the car again. It sat in garage for 2 years went through some of of wiring and soldered some connections that looked bad. The car ran great took it out drove around for about 30 minutes then started to act strange like running rough pulled in garage would not rev unhooked red wire from tps and then was able to rev. just trying to figure out where to look next. replace both amps with bosch parts. both crank sensors replaced couple years ago, tank repaired removed filter in sump and put filter in the line. appreciate any ideas. Thanks
cs81srq
Sep 22, 2023 05:23 PM
lonejag
Feb 7, 2019 03:58 PM
carsavvy
May 12, 2018 05:30 PM
Jagsandmgs
Apr 21, 2018 02:45 PM
BadKat174
Oct 17, 2014 08:00 PM
