TPS or IAC valve???
Old Mar 23, 2017 | 07:48 AM
dtony's Avatar
Default TPS or IAC valve???
So I bought a 94 XJS convertible last year. Early on (in warm weather) I'd be driving and the car began to feel as though it wanted to stall out. Losing power and getting slower. I'd pull over and either it would stall OR I'd shut it off. A moment later, I could start it up and it ran fine.
As with the first posting on this forum, I could start the engine and it runs fine. After that I may take two, three or four tries to get it to start after running a bit.
Through the winter (cold weather) the car ran fine though the starting issue continued.
A few days ago (mid March and the return of warm weather in Albuquerque) I was driving to church. When I got to the exit, I noticed that the car was idling rough as if it wanted to stall. I managed to get to church (only a few miles away at that point). Afterwards I took off the IGR valve and cleaned it. A few days later I replaced it completely.
Yesterday I was driving across town (towards church again) on a warm to hot day and about 15 mile into the trip the are stalled at speed. I coasted to the side of the hiway. It would start, but idled rough and stalled almost right away.
After a few minutes the car started and ran fine. After church last night (slightly cooler weather by then) I drove back home with no issue.
SO my question, does anyone know what the problem is??
Do I have a failing TPS or IAC valve?
I saw someone say to check connections. Since this happens in warm/hot weather could it be that warm weather causes the connections to be just a bit lose then in winter? Silly I know.
Any info you can provide is much appreciated.
Tony in NM
Old Mar 23, 2017 | 11:56 AM
orangeblossom's Avatar
Hi Tony
Do you have a V12 or the Six Cylinder?
Old Mar 23, 2017 | 03:07 PM
xjsv12's Avatar
Very similar to a fuel pump
Old Mar 23, 2017 | 03:56 PM
catterwaller's Avatar
Sounds very much like a too rich condition. Not so noticeable in cold weather. Over rich / flooding in warm weather. Air temp sensor? My 92 V12 has both a coolant temp sensor and air temp sensor. And, almost forgot, fuel temp sensor. The air temp sensor could for sure cause these symptoms. Fuel pressure regulator is also a possibility.
Old Mar 23, 2017 | 04:14 PM
Vee's Avatar
Vee
Assuming you're running the proper spark plugs, gapped, as well as cleaning out the throttle body, I will give you my advice based from an AJ16, not AJ6 (which I suspect you have) engine. They are similar enough.
1. Check the Coolant Temp Sensor. Could be bad. That could cause your problems. Its a cheap $20 part and easy to get to.
2. The TPS does make the car do crazy things. It's an awfully expensive part, so I'd hold off on that.
3. The MAF Sensor can cause similar problems. Also an expensive part.
4. Oxygen Sensors might be failing. If they are original, could be worth replacing in any case.
5. Crankshaft sensor. I've not experienced it, but I think if you do a forum search, it also tends to cause random issues.
6. Last but not least, fuel delivery issues, such as pump, regulator and filter, as mentioned before.
Without the ability to put a multimeter on any parts, it will be difficult to diagnose.
I did not think that a failing IACV would cause stalling at speed. I think you can cross that off the list.
Old Mar 24, 2017 | 04:45 AM
dtony's Avatar
It's a 6 cyl.
Tony
Old Mar 24, 2017 | 04:58 AM
dtony's Avatar
I believe I replaced that last summer along with the temp sending unit.
Over $400 for the Jag version. Was looking for the Ford/GM clone (which are $20) but not sure such a thing exits.
Replaced this last summer in an attempt to solve the Stalling issue. I also cleaned out the ERG valve as well and the stalling went away. When it happened last Sunday, I replaced the EGR valve completely.
I suspected the issues with it not wanting to start after running may be fuel pump related. I ordered one last week (before my new round of stalling) and it is on the way.
Glad to know though it is not an expensive part.
Thanks, I will check sensors you mentioned.
Tony
Old Mar 25, 2017 | 06:12 AM
dtony's Avatar
HI all,
I placed an order for new oxygen sensors this morning. The online store made mention of UPSTREAM sensor. Was that correct or is that the only oxygen sensor on the XJS???
Old Mar 25, 2017 | 06:15 AM
dtony's Avatar
PS: I intended to tinker with the XJS yesterday, but it was cooler and windy, so I opted out of that project. I did, however, drive to an event yesterday and just as I expected, no stalling, but I do occasionally get the smell of gas. I guess running rich, right? Although the car can smell "Hot" there is no indication that it is running hot at all.
Old Mar 25, 2017 | 06:30 AM
Daim's Avatar
The fuel smell could be a leaking tank - as they do like to leak. Take a sniff in your trunk.
Old Mar 25, 2017 | 07:35 AM
Vee's Avatar
Vee
Oddly enough, it's the downstream sensors you want to replace.
The upstream sensors are kinda dummy sensors. All they do is prove that the cats are doing something by showing numbers that are higher than what the downstream sensors show. Doesn't really matter how much higher, they just need to be higher.
That being said, they are far less likely to be causing you any problems.
All four sensors are identical and interchangeable.
Old Mar 26, 2017 | 07:50 AM
dtony's Avatar
This is always a great forum to find out stuff. Can you tell me where the downstream sensors are located??? I found the upstream ones.
Tony
Old Mar 26, 2017 | 09:15 AM
Vee's Avatar
Vee
Just past the cat, after the pipes bend to be parallel with the ground. You'll have to get under the car to put a wrench on them, but you should have plenty of room.
Old Apr 24, 2017 | 10:36 PM
dtony's Avatar
I took the car for a spin today in the heat of the day (to recreate the stalling issue from last time). I drove on surface streets with no issue. I got onto the highway and up to 75 MPH and it started to stumble/stall. I coasted off the road. After sitting for a few moments, it started and ran fine, just as the last time.
Any thoughts??
Tony in NM
Old Apr 25, 2017 | 01:30 AM
Greg in France's Avatar
Any thoughts??
Tony in NM
This has to be a fuel supply problem. On a V12 (I think you have a 6?) the main tank to sump tank hose falls apart internally and starves the engine of fuel. You stop and it recovers, the sump tank refills under gravity, and off you go. I would go through this aspect of the car from tank to fuel rail.
Greg
Old Apr 27, 2017 | 09:38 PM
dtony's Avatar
Greg
I have been looking for the hose you make mention of, but don't see it listed in either the online repair manual or on any part store websites. Do you know the part number or such??
Tony
Old Apr 27, 2017 | 09:46 PM
dtony's Avatar
Default Sump tank/hose for Jaguar xls L6
Greg
Tony
Old Apr 28, 2017 | 12:54 AM
Tony
Assuming you have a main tank and a sump tank and an external fuel pump, I am talking about the hose that leads from the main tank to the sump tank. no. 14 in this diagram:
But I am also saying that the entire system needs to be checked and blown through with compressed air from the boot to the injector rail inlet. It could also be the pipe FROM the sump tank to the fuel pump (no. 19) or the pipe FROM the pump to the filter, or the pipe FROM the filter to the corner of the boot where it joins the external pipe that runs under the car. I suppose it just COULD be the tank not breathing, so it would also be worth loosening the fuel cap (or somehow else ensuring air can get into the tank) and seeing if that cures it. Even new filters are occasionally faulty, and are often fitted the wrong way round, too.
Greg
