Trans light came on
Old Jul 4, 2022 | 07:15 PM
G Man's Avatar
Default Trans light came on
My 95 XJS Convert died after I came to a sudden stop. It started right back up but the trans light came on and stayed on. It’s also in limp mode. Starts out in 2 nd or 3rd gear and doesn’t shift. It’s done this before but the trans light went out as soon as it started. It has 90,000 miles and has been serviced meticulously.
Any help will be greatly appreciated.
Gary
Old Jul 4, 2022 | 07:35 PM
motorcarman's Avatar
The gearbox light ALWAYS comes on when the engine stalls!!!!!!!!!
The DTC will state that the gearbox lost RPM signal or some such wording.
Old Jul 5, 2022 | 02:38 PM
G Man's Avatar
I KNOW THE LIGHT COMES ON WHEN ENGINE STALLS!!! But it stays on and car is in limp mode. What is the fix?
Old Jul 5, 2022 | 03:33 PM
Vee's Avatar
Vee
For me, I had a transmission code. Are you able to pull codes with your 95? You have an OBD port.
The code I had showed a bad solenoid B valve. Took it to a tranny shop, they tested the valve and told me it tested well? Recommended I swap out the tranny ECU, which I did. No change.
A jag shop I took it to next recommended to swap the tranny valve body. They said they could try swapping out that solenoid, but couldn't guarantee that was the problem. They gave me a valve body from a 97 XJ6 and all has been good since.
Old Jul 5, 2022 | 03:53 PM
ptjs1's Avatar
Start by reading and clearing the codes, then see what happens.
Good luck
Paul
Old Jul 5, 2022 | 07:16 PM
Time-Pilot's Avatar
Just going to give you a bit of hope here. ON the drivers side (US) my harness had worn though after rubbing on the transmission. Actually found the solution here, replaced the two bad wired, been perfect since.
cafexjs
May 25, 2019 05:45 PM
Michael Lewey
May 4, 2018 11:54 AM
selmawp
Nov 11, 2014 02:17 AM
hoodun
Mar 16, 2012 10:19 PM
