Transmission Power Replay
Old May 21, 2020 | 10:58 AM
steveq's Avatar
Default Transmission Power Replay
Limp Home Mode issue
I have a 1994 XJS in "like new" condition. The original owner kept it out of bad weather... in short you could eat off the engine it is that clean. ( 90,000 miles in 25 years )
When the engine is cold, the transmission light will come on at titmes and the car will be in limp mode. Engine warms up, turn the engine off, start it again and the transmission light is out and the transmission is back to normal.
I know British cars very well so this issue seems to be electrical signal to the transmission SO can the transmission signal be turned off, disconnected so it does not go into limp mode. If I recall correctly the transmission is a GM item.
I believe the blue relays in the trunk are the ones which work the transmission "limp" signal but which one, or ones ??????????
Old May 21, 2020 | 01:12 PM
Jagboi64's Avatar
The transmission is a ZF, only the V12 had a GM transmission. The relay is on the right side of the trunk, I've attached the relay diagram. The limp home is a sign of a failing relay, replace it and you should be good.
File Type: pdf
Old May 21, 2020 | 02:18 PM
equiprx's Avatar
I couldn't find any engine designation on your profile.
There is a big difference in the two transmissions.
Old May 21, 2020 | 02:31 PM
motorcarman's Avatar
Jaguar also issued a TSB about the 'crappy' blue relays.
bob
Old May 21, 2020 | 02:37 PM
bob
black_cat_02
Jan 21, 2019 02:35 AM
davebaileys
Jul 6, 2017 12:09 PM
joec
Dec 22, 2013 08:22 AM
stevehill
Oct 26, 2012 10:01 PM
greenbeast01
Jun 28, 2010 04:27 PM
