Trip computer... Illumination
Old Feb 13, 2015 | 03:57 PM
Jonathan-W's Avatar
Default Trip computer... Illumination
my trip computer only illuminates for a short time after I turn the key on...
then fades to non illuminated...
is that an option or is it miss hooked up to some timer.. which is ok as most of the time at night I do not care to look at it...
I looked in my owner hand book thinking I missed out on reading how to get it to light back up, though it confirms that it just should be on when the ignition is in II...
any one have any thoughts on this?
Old Feb 13, 2015 | 04:52 PM
malc4d's Avatar
Should not do that. It will dim l believe with the dimmer control. I had to put new bulbs in mine. Which meant taking it out of the dash....bugger of a job.
Old Feb 14, 2015 | 10:12 AM
Jonathan-W's Avatar
mine acts like it is connected to some kind of timer...
does not work with the dash light dimmer...
I do not mind it going dark so much as I would like to be in control of when it so I can light it back up....
Old Feb 15, 2015 | 12:45 AM
JTsmks's Avatar
Don't know if this will help but it covers the trip computer pretty well.
http://www.backglass.org/duncan/jag/ifu/
Old Feb 15, 2015 | 05:11 AM
malc4d's Avatar
Wow, that's a great page. Unfortunately its for the pre 1991 / 1992 MY trip computer. Jag part dac 7361 / 7362.
I'm pretty sure that the light is not on a timer though. I'm not near my car this week so cant look.
Old Feb 16, 2015 | 04:52 PM
ptjs1's Avatar
Facelift computers have 2 different forms of illumination.
The buttons down the sides are illuminated through traditional bulbs, one each side which are accessible from the top of the computer. 10 mins to remove the computer and a 1/4 turn of the bulbholders removes the bulbs.
However the display illumination is achieved through 2 soldered circuit bulbs which can be prone to failure, requiring new bulbs to be soldered onto the board. Much more of a pain to access and repair.
The display illumination is also linked to the lighting circuit of the car and will dim when the vehicle lights are put on.
Hope that helps
Paul
Old Feb 17, 2015 | 02:29 AM
malc4d's Avatar
Don't forget the 20 mins or more fishing the dropped fixing bolts out of the vent area . . . .
Old Feb 17, 2015 | 09:56 PM
Vee's Avatar
Vee
Wow, that's the facelift trip computer! I assumed it would be the older style.
The bulb that lights up the buttons are the pain in the butt soldered bulbs. The bulbs that backlight the screen are much easier to access and replace. Never did understand why they did that.
Anyways, if you search my posts, I believe I explain how I replaced my backlight bulbs with LEDs. It will require a small piece of theatrical lighting gel to correct the color, but it's indistinguishable from the OEM color once done. It's also easy to do.
It will no longer dim with the dimmer, but it also eliminated the massive amount of heat imaging from that screen. Ever touch that while it's been on for awhile? Wow is it hot!
Old Feb 18, 2015 | 03:15 AM
malc4d's Avatar
It is the older computer.
Sorry, I have tried to edit my text above but cant. . . .
It should have read ' the part number for the facelift computer is DAC 7361 or 7362 depending on the market.
Old Feb 18, 2015 | 03:08 PM
ptjs1's Avatar
Vee,
Tks for correcting my mix-up re the button illumination vs the display illumination. You're absolutely right - I wrote it the wrong way around!
Paul
Goncalo Proenca
Yesterday 01:36 AM
Msteiner
May 16, 2016 12:19 AM
Joe Gandalf
Oct 1, 2015 01:16 AM
goingjag
Sep 30, 2015 09:27 PM
mrplow58
Sep 30, 2015 08:56 AM
