Twin spot light conversion
Old May 20, 2023 | 04:10 PM
Zarathushtra's Avatar
Default Twin spot light conversion
Hi,
I have a 1992 xjs 4.0 cab. I want to remove the standard lights and convert it to the twin spotlights. Please can anyone advise if it's just a matter of a swop over or would I need to change any electrical components?
Thanks.
Old May 21, 2023 | 01:38 AM
Greg in France's Avatar
Straight swap plus one bit of loom to make (which plugs into the OEM loom) to drive the H1 main beams. If you buy an SNG kit is comes with that too. I upped the main beam fuse as the entire thing draws double the current on main beam.
Old May 21, 2023 | 02:06 AM
Thanks. Would you know where I can get a reasonably priced set, even if used?
Old May 21, 2023 | 07:46 AM
Andy Harvey at Just XJS might have a set, he has decent prices. If not you are looking at several hundred pounds (eg Simply Perfoemance has sets on ebat at 500+ with no looms included)
Old May 21, 2023 | 10:57 AM
stran0020's Avatar
I have two complete sets of OEM headlights for sale located in the USA if you are interested. Thanks
Old May 21, 2023 | 03:48 PM
ptjs1's Avatar
Zarathushtra,
You MAY be able to get the early twin US headlights to work on facelift cars. However the proper conversion kits sold by people such as SNG Barratt are different for pre-facelft & facelift cars. So if you are looking for a set, you need to stop saying that you have an XJS cabriolet. Because you don't; you have an XJS Convertible. A Cabriolet is a very different XJ-S model that was only made as a pre-facelift car prior to the introduction of the Convertible.
So make sure that you tell any supplier that you have a facelift Convertible as the lights are different.
Good luck
Paul
JakieBear
Feb 22, 2023 06:02 PM
baloozman
Sep 30, 2020 09:02 AM
mannymux
Feb 10, 2013 09:30 AM
meeither
Sep 17, 2012 10:04 PM
