v-12 coil wires
Old Feb 5, 2009 | 06:57 PM
schroeterkurt's Avatar
Default v-12 coil wires
Thanks for the help. I found what i needed. Kurt
Last edited by schroeterkurt; Feb 7, 2009 at 08:25 AM. Reason: found what i needed
Old Feb 6, 2009 | 05:53 AM
michaelmarsh's Avatar
My electrical wiring manual shows the upper coil, "B" feeds the left bank "B" which is the off-centre plug on the distributor and the centre plug feeds the "A" bank from the lower coil. Of course, you have to connect the correct low-voltage three-wire connectors to the appropriate coil also, although the coils are identical, so you could feed them both the other way round and the engine wouldn't know the difference.
Good luck, Michael.
Old Feb 6, 2009 | 02:29 PM
Default coils
Thanks. Kurt
HypnoGuru
Oct 23, 2018 09:53 AM
copyman01
Nov 1, 2015 01:01 PM
hoodun
Oct 6, 2015 08:52 PM
hoodun
Oct 2, 2015 10:13 PM
Jagged-X
Sep 24, 2015 05:08 PM
