V12 fuel pump fuse ?
Old Nov 26, 2018 | 02:19 PM
warrjon's Avatar
Originally Posted by scottpeterd
Just back from the shop. Interesting find. Both the main relay and the fuel pump relay have diodes wired into the wiring harness. I unwrapped the electrical tape coming from the relay sockets to splice in my own diode. There they were.
The diodes are there are to suppress voltage spikes on the relay coils when the relays switch off. The newer relays have internal flyback diodes.
Old Nov 26, 2018 | 02:59 PM
RowlandHill's Avatar
Why do these relays fail please, i only charged the battery, some have said they fail when the car is left.
thanks
Old Nov 26, 2018 | 03:03 PM
warrjon's Avatar
Relay failure is usually the contacts getting burnt from switching. This is a perpetuating situation, as soon as the contacts have a scorch mark the contacts will arc more making the scorch worse and so on until the relay can no longer supply the current required to operate the load.
Old Nov 26, 2018 | 03:11 PM
scottpeterd's Avatar
I wonder about upgrading these 2 relays to SSR (solid state relays). It might be the end of the issue. SSRs have internal clamping diodes.
Old Nov 27, 2018 | 02:13 PM
warrjon's Avatar
SSR's do not need flyback diodes because they do not have a coil, as the voltage is turned off a coil it produces a voltage spike called back EMF, depending on the resistance and inductance of the coil this voltage can be in 100's or 1000's of volts from a 12volt source. AKA ignition coil.
The diodes in a SSR are actually a Triac and perform the switching, having the diodes reverse polarity means the switch is bidirectional.
Old Nov 27, 2018 | 02:19 PM
Warren,
That's what I was implying, just not well put by me.
Old Nov 28, 2018 | 01:16 AM
warrjon's Avatar
I would not bother with SSR's they are not infallible either, and are not a drop in replacement.
Good quality mechanical relays will last 20-30 years. All of mine are still going and my car has 270,000km on it.
Old Nov 29, 2018 | 08:02 AM
  #28
well I tested the new relay, works fine , fitted and now the pump is firing up when the ignition is on.
but sadly still no start just a whiring engine and now a flat battery
Old Nov 29, 2018 | 08:25 AM
Greg in France's Avatar
See if it will run on a few squirts of ether (starting fluid). If it does, you know fuel is the trouble. If it does not, you know spark is the trouble - and maybe fuel too! But at least once it starts on ether, you can then concentrate on fuelling if the engine still will not start without ether.
webbeing
Aug 18, 2018 10:49 PM
AZ RICH
Jun 12, 2018 01:35 PM
car5car
May 18, 2016 05:16 AM
SparkyGage
XJ40 ( XJ81 )
Apr 18, 2014 01:01 PM
wnlewis
XJ40 ( XJ81 )
Feb 9, 2009 10:47 PM
