V12 injector loom DIY build with pictures !!!
Old Dec 3, 2014 | 02:33 PM
Brake buster's Avatar
a quick update
i have just discovered that the 4 pin connectors i have used to join my looms to the main harness will also fit the marelli style coil packs
i was reading other threads on the matter and as i had some spare marelli coils turn up the other day i thought i could try it out,
and its a perfect fit , you have to use the ' male ' section of the plug , the shorter one with the yellow rubber seal on the outside that fits inside the other plug
this is only for the marelli system , as this will not fit Lucas coil packs
so i can now replace my broken plugs on the coil supplies , as the ' holder loop ' has broken off ,
BB
Old Dec 5, 2014 | 11:35 AM
warrjon's Avatar
The Marelli ignition modules are Bosch 0227 units
Bosch 0 227 100 124 Ignition Control with MegaSquirt-II
Old Apr 11, 2015 | 01:06 PM
Superb, great job and thanks for posting
Old Apr 21, 2015 | 01:17 PM
Jonathan-W's Avatar
Originally Posted by Brake buster
I got the wire from here
10M Red Black 16 AWG Soft Silicon Wire 600V 200°c 3135 | eBay
I bought multiples so I had enough to complete the project with a little spare left over
BB
thanks Brake Buster,
I have my ends, just need the wire,
I even have a weather pack crimper for the 4 wire ends...
Old Apr 21, 2015 | 02:10 PM
cool
i would buy more wire than i suggested initially , better to be looking at it than looking for it.........
good luck with the project,
do you have the markers ?
i can post out a full set to you from the UK for very little money
BB
Old Apr 21, 2015 | 03:12 PM
Jonathan-W's Avatar
got these for fuel injection... they are a lot more positive locking that the ones they are replacing...
cool
BB
no I did not get any markers
cool
BB
That would be great! PM you an Address, payment options?
Old Apr 21, 2015 | 03:48 PM
they look ok ,
pm sent
BB
Old Apr 22, 2015 | 10:15 AM
  #28
Jonathan-W's Avatar
Weather pack 4 pin male - female
any one need 4 pin weather pack connectors...?
I have more than a few extra...
Old Apr 22, 2015 | 01:54 PM
something to remember, one side of those 4 pin connectors also fit the genuine Marelli coil packs
BB
Old Apr 22, 2015 | 05:53 PM
  #30
Jonathan-W's Avatar
BB
this is TRUE
as at lunch I went out to the jaguar and unplugged the connector on the Coil and plugged in the new weather pack....
sadly as I unplugged the connector the plastic that sticks up in one part broke off and I had to go get a long needle nose and fish out the broken piece of plastic before I could plug the weather pack in or the connector that I needed to drive the car with...
ah... the parts are just OLD... new coils go onto the list...
the wiring to the coils are bear in a spot or two... time to replace with new coils new wire and new weather pack connectors....
Still I Have a boat load of them..
Old Oct 17, 2016 | 06:28 AM
  #31
Pudelspringer's Avatar
Hi BB,
Did you ever decide to make any spares?
Old Oct 17, 2016 | 12:37 PM
  #32
luds1's Avatar
HI B B Great work love the pictures and description
well done
Old Mar 11, 2020 | 07:16 PM
  #33
FerrariGuy's Avatar
Almost. For those finding this in the archives, the Jaguar harness has to be modified for BIM124 to work:
https://www.jaguarforums.com/forum/x...0/#post2202846
Old Jul 27, 2024 | 05:02 AM
  #34
Scaphan's Avatar
Just for the record in case anyone else is doing this. The connectors that are referenced above do not fit. It could be that it’s just my vehicle (xj12 1983) but the metal clips foul the injector hold down clips.
i got mine in the UK from here. https://www.vehiclewiringproducts.co...mer-connectors
Old Jul 27, 2024 | 07:34 AM
  #35
ptjs1's Avatar
Which ones did not fit on your XJ12, the ones referenced to in Post 15, or the ones pictured in Post 26?
Tks
Paul
Old Jul 27, 2024 | 10:34 AM
  #36
Scaphan's Avatar
they are the same. But I bought the ones from post 15.
Wolfy
May 28, 2024 08:06 AM
andyw
Sep 26, 2015 01:59 PM
Bcrary3
Sep 11, 2015 10:36 AM
pocketrocket
Sep 3, 2015 07:44 PM
