V12 plug leads
Old Jul 31, 2021 | 12:06 PM
brinny's Avatar
Default V12 plug leads
Any recommendations for a good set of plug leads for a v12 and uk supplier please.
Old Jul 31, 2021 | 12:19 PM
VancouverXJ6's Avatar
https://www.formulapower.com/product...rformance-set/
I used these, they are excellent but a tad tight to push on (probably better then floppy loose) and definitely noticed smoother operation vs my old ones which were probably several years old.
Old Jul 31, 2021 | 12:32 PM
Doug's Avatar
I duuno what's available in the UK.
I've been running Bosch brand on my V12 for a few years now. All's well.
Years ago, on my XJS V12, I ran OEM Rists wires for a few years. No complaints. Later I used some performance oriented wires (can't remember the brand) and noticed no improvement in running for the extra money spent.
Magnacore brand is popular with many V12 owners. High grade stuff, but rather expensive!
Old Jul 31, 2021 | 02:31 PM
BenKenobi's Avatar
I'm a Magnecor user - 8.5mm version - V12 needs all the help it can get due to the compression ratio - purchased from Larkspeed whether they're expensive depends on how you value things I guess.
Old Jul 31, 2021 | 06:38 PM
Doug's Avatar
Naturally
As the decades roll by I increasingly find myself valuing actual results quite a bit. I've found that, often as not, the extra money spent doesn't provide me any real world improvement or tangible benefit. In the case of plug wires, for example, the Bosch wires I installed several years ago are doing the job perfectly well and were $50. I'm not quite convinced that spending $150 for Magnacore would be money well spent.
Besides that, my V12 is my daily driver/commuter car. I have to save money whenever I can
Not knocking Magnacore, mind you. They have a great reputation.
Old Jul 31, 2021 | 06:58 PM
BenKenobi's Avatar
I think that the elements that made me use Magnecore (in particular the KV85's) was simply the newer technology, improved thermal tolerances, improved performance under load (designed for race etc) - and a 10 year warranty.
Standard leads are fine, not saying they aren't, I guess it is all about how they will be used (i.e. how much and what kind of driving), indeed if you look at the materials used for even the injector harness they simply aren't suitable for the ambients in the environment presented within the V of the V12, PVC insulation doesn't like continuous temperatures beyond 70°C - and I can assure you that the valley temperatures exceed that significantly when cruising, it is even worse when stuck in traffic. If you use standard leads just plan to replace them periodically then they will be fine (presumably).
Old Aug 1, 2021 | 02:14 AM
brinny's Avatar
Thanks lads
Old Aug 1, 2021 | 03:39 AM
Greg in France's Avatar
Originally Posted by brinny
Thanks lads
Brinny
You could try Mr Retro Leads:
https://mrretroleads.co.uk/
I bought some of his 8 or 8.5mm mm ones, precisely the same as magnacore and half the price. Very good indeed. Formula power also very good. Both UK firms.
Greg
Old Aug 1, 2021 | 08:05 AM
BradsCat's Avatar
The OEM wires were 7mm. Several years ago I ran a test in the garage with all the lights off and was shocked to see the amount of arc'ing around the distro and wires. Converted to 8mm (can't remember the brand, blue with red plug tips) and the arc'ign was immediately gone.
Old Aug 2, 2021 | 02:09 PM
brinny's Avatar
Brinny
Greg
Thanks greg
Old Aug 2, 2021 | 02:10 PM
brinny's Avatar
Interesting. 8mm it is then.
Old Aug 2, 2021 | 03:23 PM
ronbros's Avatar
my wires are 26yrs old , so far perfect no problems, nice long push on plug end to keep spark leak down(nonexsistent), and cut to fit length into distributor!
plus a a good look for eye ball enjoyment!
Old Aug 8, 2021 | 03:49 AM
FinCat's Avatar
Not straight answer to original question, i have yellow Accel Race 300+ leads on my P38A Range. Bought long time, +10years, ago and still going strong, only negative thing is you need to build them from kit as Ron said.
My mate had same leads on his 360 Mopar, leads often hanging on exhausts manifolds but no harm done.
Personally i wouldn't put yellow leads on stock V12 engine bay... think they will scream attention just too much.
Old Aug 8, 2021 | 11:04 AM
ronbros's Avatar
i have painted my personal engines RED since 1949!
if it dont go Fast make it look good!!
olivermarks
Feb 17, 2018 07:59 PM
Andreas Schmieg
Jan 27, 2017 07:15 PM
tizzle
Dec 8, 2011 06:33 PM
velder
Jul 6, 2011 01:28 PM
