Vacuum hose sizes
Old Nov 26, 2020 | 08:58 AM
Pirk's Avatar
Default Vacuum hose sizes
Wanted to confirm the main vacuum hose sizes, maybe somewhere in the ROM or parts guide that I missed....
  1. 2mm ID x 4mm OD - black with yellow stripe
  2. 2mm ID x 6mm OD - black fabric wrapped
  3. 4mm ID x 7mm OD - black with white stripe
  4. 4mm ID x 8mm OD - black with orange/peach stripe
  5. 6/7mm ID x 14/15mm OD - black, some looks reinforced others not
#1 - black with yellow
#2 - fabric
#3 - black with white
#4 - black with orange/peach
#5 - black
Old Nov 27, 2020 | 05:26 PM
92/93 XJS's Avatar
Many thx for these specs. I am trying to get my 92 6cyl C/C working and suspect vacuum lines. This will help if someone knows if the sizes are available at the usual aftermarket stores or not?
Old Nov 28, 2020 | 05:56 PM
Pirk's Avatar
The black fabric one is actually 3mm or so. Typo in my part
Old Nov 28, 2020 | 11:00 PM
VancouverXJ6's Avatar
Whats the purpose of fabric? I should probably redo my lines they're original
Old Nov 29, 2020 | 01:22 AM
Greg in France's Avatar
I recommend buying silicone vac pipes as replacements Also, if you have the GM400 gearbox, replace the vac modulator vacuum pipe too. The gearbox is far more responsive with a good vac pipe, and silicone is far more heat resistant.
Stuart@VelocityAP
XE ( X760 )
Jan 23, 2021 07:57 PM
ricardoa1
May 15, 2020 03:02 AM
djgold
Feb 15, 2020 07:26 AM
HaydenS
Jan 9, 2018 09:44 AM
Meister_Kajo
May 5, 2017 02:57 PM
