Water leak sources
Old Dec 13, 2009 | 10:16 PM
Thermo's Avatar
Veteran: Navy
Rich, it could be so many things. Could be a freeze plug, could be a bad head gasket, could even be a cracked block/head. The options are limitless. Unless you can see where the water is coming from, I would either walk away from the car or only get it if it is a steal. But, probably, any which way you look at it, pulling the motor to fix the problem will be part of the fix. If not, atleast pulling the heads off. Lots of hours of labor to make the fix. So, unless you are good with tools.......
Old Dec 14, 2009 | 11:47 AM
Sarc's Avatar
Hi Rich
As Thermo said, it could be from a lot of different places so unless you can see it, you're going to be taking a bit of a gamble. I had what I thought was a leak between the block and the front timing chain casing...... which would have probably been the end of the car, but it turned out to be a leaking hose that was letting water run down the side of the block. "Luckily" the hose burst a few days later and after I replaced it the side of the block where I thought I had my fatal leak became bone dry and has stayed that way since.
Another concern I would have is that if the car is leaking a lot of water, is there a possibility it's been ran dry and overheated at some point ? (Overheating is FATAL for the V12 engine)
Let us know how you get on.... it's always good to hear another XJS getting a reprieve from either the knackers yard, or a V8 conversion
clubairth1
30
Sep 3, 2025 04:38 PM
aholbro1
Dec 29, 2024 06:46 PM
Saturbo
Sep 8, 2015 07:35 PM
1100me
Sep 7, 2015 06:26 AM
