Well tackled my windshield wiper today LOL
Old Jun 8, 2019 | 02:56 PM
Kriss Vector's Avatar
Default Well tackled my windshield wiper today LOL
Didnt think it was going to be this bad.
Old Jun 8, 2019 | 02:57 PM
I am amazed that no fuses blew All fuses are good, I guess the coil opens ?
Old Jun 8, 2019 | 04:12 PM
J_C_R's Avatar
I was able to rebuild my motor...once. Lasted about two years, and then its second life ran out.
I don't see them in your photos, but you can coax the two big magnets out of the housing, clean it as best you can, then epoxy them back in. Your other options are to buy an NOS part if you can find one, get one from a junkyard (which may not be in any better shape than yours) or come up with a more radical solution.
I ended up using a new, good sized DC motor that I coupled to the wiper drive shaft with a chain drive arrangement. It works fine, but it has only one speed, doesn't park itself, and sounds like a chain saw running when it's on.
Good luck with it.
John
1987 XJ-S V12
Old Jun 8, 2019 | 05:17 PM
Good luck with it.
John
1987 XJ-S V12
The chainsaw sound is actually awesome, there is a member who reached out to me about having one thanks.
Old Jun 9, 2019 | 08:15 AM
JigJag's Avatar
That looks totally rebuildable! It’s when they eat the magnets that they get difficult to fix. I wouldn’t toss it.
remove all rust with phosphoric acid, neutralize, clean, lubricate and reassemble. Then seal the damn thing. You’re missing the plastic cover for the motor and gearbox. The repair won’t last long un-sealed and uncovered. If the new one you get from a member comes with a cover then great! Otherwise seal it, or it’ll do the same.
Old Jun 9, 2019 | 08:32 AM
Sounds like a plan, il give it a shot..thanks
Old Jun 11, 2019 | 10:21 PM
Got it all apart and cleaned, ready to go back together, i got lithium grease for the gear box but what do you suggest for the coil and magnet ??? what do you guys use for lubrication on that, i was gonna put some of the same stuff that we use on light bulbs.
Old Jun 12, 2019 | 12:07 PM
JigJag's Avatar
I sprayed them with white lithium lubricant to create a barrier to oxidation.
Old Jun 12, 2019 | 05:11 PM
Segfault's Avatar
I use graphite grease to lubricate computer fan motors, I'd use it for any small electrical motor. It will lubricate even when it dries off.
Old Jun 12, 2019 | 11:26 PM
Ok got the motor lubed, transmission lubed and all back together, went to re-install it and noticed the wiper park switch was all corroded and crumbling in my hand, Does anyone know how i can directly wire this up without using the park switch ( WIRE TO WIRE ) Thanks
Old Jun 13, 2019 | 04:21 AM
JameyXJ6's Avatar
I rebuilt mine about 7 years ago but this time the magnets are broken and the armature has shorted out beyond repair.
Anyone have a replacement motor?
Old Jun 13, 2019 | 04:38 AM
where are you located, i just found a guy in Daytona beach, he told me he has a hangar full of stuff.
Old Jun 14, 2019 | 09:34 AM
JameyXJ6's Avatar
Hinsdale New Hampshire.
I’m picking up a Jeep Assembly next week and I’m going to try altering it to fit. If I’m successful I’ll post updates
Old Jun 14, 2019 | 10:31 AM
Please let me know I still didnt get a answer from anyone if i can rewire mine without the park switch and what wires to use if i just want high speed thanks
Old Jun 19, 2019 | 06:05 PM
JameyXJ6's Avatar
Well I’ve got the donor assembly and I’m trying to figure out the wiring. So far I’ve got low and high speed but no park, and I’m going to have to shorten the donor assembly about 2-3 inches but I don’t see that being much of a problem
Old Jun 21, 2019 | 12:21 AM
Default found the perfect lube for the motor
I have found the perfect lube for the wiper motor ( internal and external parts ) works on lubing electrical components.
Timbo
Aug 15, 2016 07:16 PM
QuartzSTypeR
25
Mar 17, 2014 12:11 PM
aahmichael
Jun 21, 2012 12:17 PM
Anticitizen
Dec 7, 2011 06:11 AM
