What is this Fuse For XJS V12
Old 08-21-2016, 06:01 PM
orangeblossom's Avatar
Received 3,752 Likes on 2,600 Posts
Default What is this Fuse For XJS V12
Hi Can anyone tell me what this fuse is for
Old 08-21-2016, 06:05 PM
Daim's Avatar
Received 2,180 Likes on 1,583 Posts
It's not factory... So you'll have to trace it. Does the car have an alarm?
orangeblossom (08-21-2016)
Old 08-21-2016, 06:22 PM
Mac Allan's Avatar
Bodge?
Old 08-21-2016, 06:36 PM
Hi Daim
This Car has a Scorpion 197 Alarm Immobilizer and I think it is the reason why the Car won't start.
The Key Fob button doesn't work even with a new battery, even though I accidentally managed to disarm it by touching two wires together.
Do you know if an immobiliser switches off the fuel injection or what it does so the Car doesn't start.
I would really like to get rid of the Immobiliser altogether if only I knew how.
Old 08-21-2016, 07:15 PM
Daim's Avatar
Normally immobilisers will either interrupt fuel or spark supply. It sounds like an aftermarket installation. See if you cam find the box and trace back the wires. Remove and achieve factory setup again and then try. Just pullong a fuse isn't enough... As you'll still be stopping the power from key to injectors/coils.
orangeblossom (08-22-2016)
Old 08-22-2016, 02:14 AM
Hi Daim
Its a very sophisticated Alarm that seems to be plumbed into the main wiring loom and the PO paid around £450 to have it fitted as an option back in 1990.
For which I am assuming that it does a bit more than sound the horn and flash the lights, as such I wouldn't be surprised if it also interrupts the fuel supply.
The problem is it no longer responds to the Signal from the Key Fob.
So not being a Car Alarm expert, it could be a difficult part of the problem to eliminate, if it turns out the injectors are not getting a Signal.
Old 08-22-2016, 12:38 PM
Mac Allan's Avatar
Hi Daim
Couple of suggestions. Contact the company and/or order a replacement remote:
Scorpion Automotive - Supplier and manufacturer of vehicle security alarm systems and mobile communication Interfaces
Either they can tell you why the system isn't responding to the remote or how to reprogram it, or send you a replacement.
You could also see if they have installation instructions available, which you could use to "uninstall" the system.
Old 08-22-2016, 02:29 PM
Hi Mac
Cheers, I'll see what they have to say.
sonny2
08-18-2016 07:36 PM
plums
08-18-2016 04:23 PM
Darren.morgan
07-27-2016 05:46 AM
rwilcoxen
07-25-2016 01:04 PM
pfj
07-23-2016 04:09 AM
Quick Reply: What is this Fuse For XJS V12
