What Size are the Brake Bleed Nipples XJS V12
Old Jul 31, 2020 | 12:11 AM
orangeblossom's Avatar
Default What Size are the Brake Bleed Nipples XJS V12
Hi Guys
What Size are the Brake Bleed Nipples on an XJS V12 as I would like to get some New Ones
Old Jul 31, 2020 | 02:06 AM
Greg in France's Avatar
OB,
All I know is that the fronts are larger than the backs! To my shame after all these years I do not know the thread sizes, neither do i know the sump plug thread size. An opportunity for someone to create a sticky!
In the meantime, I would ring up Wards in Colchester, they will tell you and sell you some!
Old Jul 31, 2020 | 02:39 AM
ptjs1's Avatar
OB,
Fronts are £2 from Jaguar and st least you'll know they'll fit.
Paul
Old Jul 31, 2020 | 10:32 AM
Jagsandmgs's Avatar
They areFront
M10x1.0
Rear
3/8x24
If you are at Autozone the “Help” section has speed bleeder replacement bleed nipples in those sizes that work great!
Old Jul 31, 2020 | 10:33 AM
Dukejag's Avatar
I can help you with that, I have installed brake bleeders on mine and it is an easy one man job to flush the brakes.
Front are M10 x 1mm (16mm long) - that is the length of the new bleeders.
Rear are 3/8 x 24 (16mm long)
I originally purchased 4 x M10 x1mm as that is what is listed on their website and they only fitted the front, using a thread gauge I worked out the rear were 24 pitch and purchased a bolt and it screwed in,
So I swapped the M10's for the 3/8th ones and installed them last night.
Once installed, I connected a hose with a rubber cap to the nipple, open the top of the nipple and then just bleed them, tighten when finished.
That easy. I have them on 3 x motorbikes and the XJS - not cheap but dam they are good.
https://www.stahlbus.com/info/en/ser...other-products
Old Jul 31, 2020 | 10:44 AM
Jagsandmgs's Avatar
How much are those fancy German bleeders? You can get the Help USA speed bleeders as cheap at $8 a pair at Rock Auto but I really like that o-ring idea that you linked to.
Old Jul 31, 2020 | 03:57 PM
Hi Guys
Jagsandmgs/Dukejag/
I've found some BF Goodrich Speed Bleeders which are 3/8 unf but it doesn't say how long they are (does length matter?)
2 for £26
Will these be ok for the Rears, as Bleeding the Front ones isn't too much of a problem
The Fancy German ones are about £27 each!
Which for me does not seem worth it for a job you are only doing once a year
Old Aug 4, 2020 | 09:51 PM
Rescue119's Avatar
I have the rear ones from rockauto and they worked great.
Old Aug 5, 2020 | 03:14 AM
Hi Rescue
Mine should be arriving Today or maybe Tomorrow 'with any luck'
Old Aug 5, 2020 | 04:45 AM
ptjs1's Avatar
OB,
I've been doing some research on these and other similar items as they seem a good idea.
Looking at the reviews, it seems to be absolutely critical to take care when installing them. There are a number of people who apparently sheared off the head when fitting them. With a relatively thin wall casting, you must be careful when tightening them. Read all the reviews on Amazon etc. before you fit them.
Good luck
Paul
Old Aug 5, 2020 | 05:33 AM
Hi Paul
That was one of the reasons, why I didn't buy those and so instead I bought some solid steel ones from BF Goodridge where by way of a bonus they were only half the price, although they didn't arrive today as I was expecting they would
But I get what you say, so in any event will be Careful during the Install as I really don't think that I could hack another broken bleed nipple so soon after the last one
Cheers!
Alex
bvandyk
Jun 27, 2019 07:01 AM
BNS1
Jun 8, 2018 10:01 PM
NewF999
Jul 9, 2012 10:57 AM
thuffner3
May 27, 2011 07:23 PM
ghheath
May 16, 2010 04:57 PM
