What's this part?
Old Dec 26, 2024 | 09:33 AM
codoug's Avatar
Default What's this part?
Can someone tell me what this red colored part is.  I noticed the wires to it are broken and 1 wire is too short and cant be reattached.  So hoping I can get a replacement but Ive looked thru the service manual and cant seem to find it.  Its on the drivers side near the firewall.  Also anyone know where to get replacement harnesses?   Ive seen some on ebay that had crazy high prices.
Can someone tell me what this red colored part is. I noticed the wires to it are broken and 1 wire is too short and can't be reattached. So hoping I can get a replacement but Ive looked thru the service manual and can't seem to find it. Its on the drivers side near the firewall. Also anyone know where to get replacement harnesses? I've seen some on ebay that had crazy high prices.
Old Dec 26, 2024 | 10:33 AM
jag-reflex's Avatar
Just a connector plug. You'll find them all over the car; under the seats, fog lamps etc.
Old Dec 26, 2024 | 05:14 PM
codoug's Avatar
Any idea why they'd use a big plastic tube like that just to connect 2 wires as that doesn't make sense to me. If it's just a plug that doesn't do anything except connect 2 wires, can it just be bypassed? I was thinking there might be something electronic in the plastic tube.
Old Dec 26, 2024 | 06:49 PM
jal1234's Avatar
They are quick disconnect connectors, similar to what is used all over modern cars. They make components easy to replace, without cutting wires.
Old Dec 26, 2024 | 11:32 PM
codoug's Avatar
Thank You. I'll just make some new connections and get rid of the plug. No wonder I couldn't find it in the service manual!
Old Mar 17, 2025 | 10:20 AM
Nap's Avatar
Nap
Sometimes these older cars seem so much easier to work on, and sometimes they seem so infuriating. But it is nice to see the manufacturers incorporate this more user friendly tech.
Old Mar 17, 2025 | 11:06 AM
Asdrewq's Avatar
On my car (UK 1989) the red plug with orange/black wires connects to the microswitch near the throttle mechanism that clicks on as soon as you slightly touch the throttle. It tells the ECU 'We are no longer idling, something is happening!' I think.
It's loomed up with an identical Black connector with a loop of wire on one end, and a much larger black cylindrical connector, both of which don't really connect to anything aside from back into the loom. Can't see why you couldn't tidy them all up.
Old Mar 17, 2025 | 12:07 PM
Jagsandmgs's Avatar
Don’t remove the black one that just loops back in on itself! That’s the strategy selection link. When you're traveling in a country with poor fuel quality, you pull the link, and the ECU will retard the ignition timing.
Zen Beer
Mar 11, 2024 09:19 AM
Jrizzo003
Feb 10, 2024 01:33 PM
Elm
Jul 30, 2023 05:50 AM
MaxTorq
May 24, 2021 10:25 AM
SableXJ6C
Dec 16, 2018 11:23 AM
