Whelp that was a close one...
yep
I did all the hoses except the one leaking, the inlet side to the fuelrail and the small one off the fpr. They will now be getting done!!
Those OEM hoses are incredible. When replacing my questionable Cracking fuel lines I pressurized the system and began picking at them with my nails. Removed the entire exterior rubber layer and still no leaks!
Right? Cutting through the old ones to get them off the injectors is really a lot of work. Its like they turn to plastic
yeah cutting them off was a complete pain! Seems this return hose had too much heat
exactly why i went with 5/8" inside diameter solid aluminum rails.
NO socalled fuel hoses at all.
injectors have hi-pressure O-rings top and bottom, and all lines are ultra hi pressure stainless flex and aeroquip fittings .
lot of work but should last as long as i do?
thats cool 👍🏼
don't forget the hoses from the pressure regulators to/from the fuel rail, the hose to/from the fuel cooler and the supply/return lines connected to hard points on the firewall. And finally the rubber hoses over the IRS cage that are the feed/return lines to the tank. Those hoses are the same age.
