When accelerating engine cuts out
Old Apr 28, 2017 | 07:02 AM
JimmyGrieves's Avatar
Default When accelerating engine cuts out
Hi
I am proud owner of a 1984 XJ-SC 3.6 Manual, however unfortunately not very mechanically minded. Unfortunately it is not running very well and I am having little success of a cure. When accelerating the engine often cuts out and I have to pull back and try again, feels like the engine is cold or fuel not getting through. Initially had someone to retune, which wasn't the problem, he highlighted that when idle gas reading 1.5%, however at 3500rpm 10% which should be 0.5%. He suggested, Fuel Injection Coolant Temperature Sensor - which I replaced, no change, and ECU, which I sent to Blue Streak who repaired the pressure sensor, still no change.
Any other ideas, gratefully received.
Thanks and best regards
John
Old Apr 28, 2017 | 04:39 PM
Greg in France's Avatar
If those figures mean the car is running very rich, I would suggest leaking injectors or maybe a throttle position sensor not functioning correctly
Old Apr 29, 2017 | 09:30 PM
NJ2003XJ8's Avatar
I have a similar car with similar problem. In my case when I accelerate car often does not start accelerating right away. Sometime it makes 'coughing/farting' sound for a moment and then takes off. Getting off pedal and back sometime help, but no always.
I replaced TPS to no effect.
If yours is loosing power during acceleration, one of the things to check is fuel filter. If it is getting clogged - it may not keep-up with quick demand for fuel causing power loss. In theory same effect can happen if fuel tank ventilation is not working creating vacuum in the tank (rare, but happens).
Old May 3, 2017 | 02:59 AM
Thanks for the posts. Will give them a go.
Old May 3, 2017 | 06:33 PM
Mac Allan's Avatar
Does it do this after the car has gotten warm?
I seem to remember that could point to a failing Ignition Amplifier. Perhaps those more expert on the Lucas system can chime in.
Old May 4, 2017 | 03:32 AM
Unfortunately no difference once warmed up.
BCJAG
XF (X260)
Oct 20, 2016 02:24 PM
xjack
XJ40 ( XJ81 )
Oct 16, 2016 09:27 PM
Mbourne
Oct 10, 2016 09:30 PM
Miss Charlee
Oct 5, 2016 07:03 PM
Eskr
Oct 4, 2016 11:42 AM
