Where to get 3/8 stainless steel fuel pipe ?
Old Mar 3, 2022 | 11:37 AM
eurolat's Avatar
Default Where to get 3/8 stainless steel fuel pipe ?
In some places under car I found squashed ( flattened) fuel line.
So I decided to change old steel fuel hardline to stainless steel pipe.
Does anyone know, where in Europe I can buy a 3/8 seamless stainless steel pipe, 4 meters coil ? (The pipe must be made in USA or Europe, but not in China.)
And can Swagelok compression fittings be used in fuel hardline connections ?
Old Mar 3, 2022 | 12:00 PM
Greg in France's Avatar
This is the stuff you need, and they sell the fittings too, also very decent people, helpful and efficient:
https://www.wrightsautosupplies.co.u...e-pipe-tubing/
Old Mar 3, 2022 | 12:01 PM
kansanbrit's Avatar
Why not use rubber?
Old Mar 3, 2022 | 12:03 PM
Fraser Mitchell's Avatar
I'm puzzled you're wanting to use stainless steel pipe, which will be extremely hard to bend and also form connections, when you could be using Kunifer pipe. This is a cupro-nickel pipe, and easy to bend and form into connections. You can use compression fittings too. When I rebuilt a Mark 2 in the 80s I used kunifer pipe for fuel and brake lines. The name represents the constituents of the metal, (Copper, nickel, iron).
Here is a UK supplier, there will no doubt be US suppliers too.
https://www.gsparkplug.com/transmiss...mbing-gas.html
Old Mar 3, 2022 | 03:22 PM
garethashenden's Avatar
10mm tube may be easier to find, its only 0.5mm bigger than 3/8".
Old Mar 3, 2022 | 03:32 PM
Jagboi64's Avatar
The existing line is 3/8" and a compression fitting will not work with the difference in size. The fit on the furrels is very tight to make a leak free joint.
You could go to a nylon line, many of the OEM's use that as fuel line. You'd need to make ribs on the ends to have the nylon fit and stay on the existing pipe though.
adenshillito
Feb 8, 2016 06:56 AM
x300killer
Apr 21, 2012 04:22 AM
Brake buster
Oct 2, 2008 07:28 PM
