While being stored - Better to start it or leave it be?
I bought my 1996 XJS at an auction, had it shipped to me, and then immediately had to put it into my garage for winter storage due to snow, ice and salt on the roads. I have not even registered or insured yet and will not until the spring. I have it on a trickle charger and have been starting it and driving it up and down my driveway for about 10 minutes weekly. In your opinions is it better to do that 10 minute procedure or would it be better for the car to not start it and drive for that short time and distance? I do get some strange looks from my neighbors and passing cars driving the convertible up the driveway in 0 degree temperatures.
P.S. - Do you store your convertible with the top up or down. I previously had a 1989 MB 560sl and stored it with the top up and wound up with split threading on a seam. It was the original top, however.
By the way, after reading here about the OBDII port on the 1996 I attached my reader when I started the car today and no codes appeared. That is a good start to my ownership.
Greg in France (12-23-2019),
Mguar (12-24-2019)
I mainly worry about a/C seals with just letting it sit. I go back back and forth about this. I think it may be best to just drive the car for 30 minutes or so with AC on at least once a week. If I don’t do this, I start getting fluid leaks.
For 15 years, one of my Jags has been standing still for half a year and has never had a leak somewhere. Perhaps when you store in a very warm garage.
I think the most appropriate procedure depends to a large extent on storage location. If the vehicle is in a (preferably heated) garage and on a battery tender, short warm ups can do more harm than good. If the location is less ideal then a monthly thorough warm up, preferably with a short drive to get exhaust, transmission and brakes up to temperature is preferable.
One thing I do, regardless of lay up or regular use is to cycle the AC through max cold to max hot on a monthly basis. This keeps air distribution flaps and servo vacuum motors operational.
The following 2 users liked this post by GGG:
Grant Francis (12-23-2019),
Good tips everyone, thanks.
I will keep it on the battery tender. I put the top up. I cycled through the a/c settings. I checked the pressure in the tires and it is a specially good thing I took that advice. The car had only 23psi in each tire. I got out the old bicycle pump and got each one up to 38 psi. That was enough for these arms for today. I also covered the tailpipes and air intake with aluminum foil.
If I cannot stop myself I will start it up once a month and drive it in the driveway (snow permitting) and run the a/c.
I checked on that issue regarding the registration and insurance and that is not a problem. I will take a chance on not insuring it this winter while I am storing it. I really don't have that much money sunk into it as of yet. We will see what happens in the spring when I get it on the road.
all I can say is that the owners manual specifically states the a/c must be run weekly for at least 10 minutes , even during the winter, to prevent seals from drying up
The result: contamination of the internal parts of your engine. With gasoline engines you get a deposit on, for example, the gas valve.
This actually happens about the same as when you only make short journeys by car and just don't get warm enough.
944xjs (12-26-2019)
The engine uses an extra rich mixture at stationary speeds. This means that a relatively large amount of fuel is injected in proportion to the amount of air that is used during combustion.
but I guess this thread is more about guys in places where you have to store the car for the entire winter...I don’t know what Jaguar recommended for that particular scenario, but as I mentioned before, they did recommend running that compressor for 10 minutes per week to lubricate seals.
YYC guy
01-21-2012 03:45 PM
