White spirit and brake pads
Old Oct 12, 2019 | 04:39 AM
ptjs1's Avatar
Default White spirit and brake pads
As part of cleaning off the old wax and underseal on my rear cage, I'm spraying a fair bit of white spirit in the general area. The brake calipers and pipes also have wax over them so I'm trying to clean that slso. Will the white spirit soak into the brake pads and ruin them or will I be ok?
Any thoughts appreciated.
Paul
Old Oct 12, 2019 | 05:24 AM
Should be OK, as White Spirits evaporates quite quickly.
Then think of all the road gunk they must contend with, I doubt they will complain.
A quick squirt of water will do no harm, just in case. A simple pistol grip sprayer with water will suffice.
Old Oct 12, 2019 | 05:26 AM
orangeblossom's Avatar
Hi Paul
Personally I wouldn't use White Spirit as it may soak into the Pads and not come out
What I have used instead is Wynns Brake Cleaner, which almost instantly evaporates and is a lot cheaper than a New set of Brake Pads
Old Oct 12, 2019 | 06:58 AM
anyoldiron's Avatar
Banned
Personally, i NEVER EVER ever ever use contaminated brake pads/shoes, i am not a chemist and have no clue as to what chemicals pads/shoes may or may not be resistant to. What i have seen is the end result of shoes that have de- laminated and have felt breaking with oil on pads or rather the lack off at the worst time. l wouldnt like to think about the fallout of being in a accident in a vehicle that was found to have contaminated brake pads..................................and then for it to be found out it was me that contaminated them.
Dont **** around with brakes.
Old Oct 12, 2019 | 09:14 AM
Greg in France's Avatar
Paul
I suggest you remove the pads first Peter. Then you can have a good look at them and then you can have a good think and then you can buy a lovely new set. 40 quid well spent and no worries.
Old Oct 12, 2019 | 09:39 AM
Doug's Avatar
"White spirits" is a little vague
In the USA we'd say "Solvent" or "Mineral Spirits"....but these are also vague. "Stoddard Solvent" gets a bit more specific
Anyhow......
There are lots of different formulations that fall under these rather generic names. Since I struggled with chemistry in high school I'm always at a loss.
The standard I use regarding solvents (or any other liquids) and brake pads/shoes is "After drying, does it leave a stain?" . If there's no stain my assumption is that there's no residue left behind and therefore, no worries. I'm not saying I'm correct. I'm just saying that's the standard I go by. Nothing bad has ever happened...so far.
coxzilla97
Aug 6, 2017 09:02 AM
miamijag
Mar 26, 2012 09:44 PM
ndy4eva
24
Jun 16, 2010 05:20 PM
andersen06
Jan 16, 2010 11:36 PM
