Window runner grease
Old Apr 10, 2019 | 01:47 PM
brinny's Avatar
Default Window runner grease
While the door cards are off I thought it would be a good idea to clean out and replace the window runner grease with some fresh. Any suggestions to the best grease to use and how much should I use? Many thanks all in advance..
Old Apr 10, 2019 | 03:12 PM
Greg in France's Avatar
Assuming this is for the metal window fixtures in the track? if so I would use a moly grease of some sort, eg
https://www.ebay.co.uk/p/Bisley-Gun-...d=282884441859
Greg
Old Apr 11, 2019 | 12:45 AM
Crackerbuzz's Avatar
I used silicon spray. Worked a treat for me
Old Apr 11, 2019 | 09:33 PM
warrjon's Avatar
Depends on what you mean. If the power window scissor mechanism then Molly grease. If the slides that the glass run in use silicone spray, grease in here will collect bust and wear the glass.
Old Apr 12, 2019 | 05:25 AM
Vee's Avatar
Vee
Old Apr 12, 2019 | 09:27 AM
brinny's Avatar
Thanks all
TOMALONIC
Nov 19, 2021 11:24 PM
Winks
Nov 17, 2014 08:38 AM
suprasix30
Mar 4, 2014 03:43 PM
seanshamrock0000
Mar 12, 2011 06:57 PM
TOMALONIC
Apr 22, 2010 08:31 AM
