Windscreen washer jets
Old Nov 4, 2022 | 01:42 PM
leep123's Avatar
Default Windscreen washer jets
Hi, quick question on washer jets.
My '90 coupe has windscreen washer jets with a single slot headed screw at the top and an open slot in the side of the screw head where the washer water exits from. I think these are the heated variety as illustrated in the workshop manual.
The slot headed screw rotates to aim the direction of the water spray. Does this screw also adjust the amount of water coming out of the nozzle i.e., if unscrewed outwards will I get more water flow, or does it just rotate without affecting water flow rate?
Trying to sort out the very low flow rate out of my washer jets despite a new pump, clean fluid and I don't believe there are any blockages.
Cheers,
LeeP
Old Nov 4, 2022 | 01:45 PM
Jagboi64's Avatar
I think they only adjust direction, not flow. If there is low flow, try putting some air through the nozzle backwards to flush out any dirt that might be in there. It's a very small orifice, so easily clogged. Perhaps also try pulling the tubing off the nozzle and seeing how much the pump puts out, you might have a tired pump or a kinked hose somewhere.
Old Nov 4, 2022 | 01:50 PM
leep123's Avatar
Thanks, I'll check that out. Thanks also for the super quick reply - 3 minutes, is that a record?
Cheers,
LeeP
Old Nov 4, 2022 | 04:01 PM
rgp's Avatar
rgp
I could never get mine to flow nicely the water just fell out of the jet, as it turned out the jets had been poked around so much over the years it was non repairable. So fitted some thin jet easily obtainable jets. Now I have super car washers. Lol
Old Nov 5, 2022 | 12:36 AM
Greg in France's Avatar
RGP
I did the same, fitted three of them across the wiper grill, and fitted a Delphi headlight washer pump too. Brilliant, and as there is enough water on the screen the Lucas wiper motor is not strained either.
Old Nov 5, 2022 | 04:49 AM
rgp's Avatar
rgp
"3", I never thought about that, I can feel a job coming on, 😀 I changed the Lucas excuse for a motor for an electrolux which is proper
Old Nov 6, 2022 | 10:44 AM
leep123's Avatar
Hi rgp,
Can you remember where you bought your washer jets? I'm struggling to find any on-line that are thin enough to sit between the ribs of the black air intake grill. Do yours have a nut beneath to hold them in place or sprung lugs that engage when the jets are pushed down?
Thanks,
LeeP
Old Nov 6, 2022 | 12:42 PM
Leep
This firm is a good source for all sorts of bits:
https://www.carbuilder.com/uk/search?q=washer+jets
On my car I used Ford Mondeo jets.
Old Nov 6, 2022 | 01:00 PM
leep123's Avatar
Leep
Thanks Greg - useful site.
Did the Mondeo jets fit between the ribs of the ventilation grill? On my grill it looks like the body of the jet would have to be 13mm wide max.
Cheers,
LeeP
Old Nov 6, 2022 | 11:28 PM
They did fit, I might have had to just file them a touch, cannot remember. But they are between the ribs, no bother.
Old Nov 7, 2022 | 05:20 AM
rgp's Avatar
rgp
Originally Posted by leep123
Hi rgp,
Thanks,
LeeP
Sorry only just read. I got from need to file a little bit
https://www.ebay.co.uk/itm/144236421317
Old Nov 7, 2022 | 07:35 AM
leep123's Avatar
Thanks, I've ordered a set. Have also gone for a set to fit a Mondeo as a reserve following Greg's experience.
Cheers,
LeeP
drbill
Mar 9, 2022 02:30 PM
1sloXJR
Jan 18, 2021 08:09 AM
mhamilton
Jun 13, 2018 11:10 AM
Greg McDonald
Jun 11, 2018 02:40 AM
wackymatt
Jan 26, 2015 07:20 AM
