wiper motor issue...
Old Sep 24, 2023 | 06:34 PM
rckunze5's Avatar
Default wiper motor issue...
hello-
1982 US version HE... I have had some various electrical issues, and 'think' I have them all figured out... but the wipers are frustrating me.
I pulled the motor- just used a spare battery to connect, and it does run.. Put it back in- ended up replacing the wiper relay. I had not tightened up things... but started the car, and the wipers worked!!!... Great!... at least the motor ran, and the posts were turning.
So I tightened up everything, put wipers on- started the car- and the wipers did not work. Checked fuses, all were still good. I thought maybe something was binding, holding up the wipers. So I just loosed up bolts, even took the wipers off-- started the car, and the wipers... do not work.
So... any ideas? I don't think the relay is shot- I will pull it again and check. Fuses are good. Is there something simple I am missing?
We have been working on this beauty for 4+ years. She runs, stops, everything 'works' - except for the wipers. Right now- I am not in too much of a hurry- as found out the gas tank is leaking when full. (pulled it, removed pad- we have only been doing everything on 1/4 tank as we get it running); I have a shop building an aluminum replacement... this was the father/son job- so my son has a sweet ride to school for his senior year.... (yeah- what kid drives a V-12 Jag to High School?....)... so any suggetions please.
Old Sep 24, 2023 | 09:59 PM
xjtom's Avatar
perhaps some not so secure wiring at the motor, i'm guessing you checked for power at the motor when wiper switch on? below is an extract from schematics i reproduce, hope it's of some help, you say wipers worked after car start up and initial check, was the wiper unit in normal position or upside down - just sitting on sill?
Old Sep 25, 2023 | 08:33 AM
rckunze5's Avatar
Thanks- The unit was 'installed'... but just set into the opening- not bolted in. I will pull and double check power when switch is on.... after the tank is back in...;-)
Thank you again for the schematic...
Old Oct 23, 2023 | 08:31 AM
rckunze5's Avatar
Default Found issue...
Just an update. I took the wiper- motor apart- some slight rust- that I used 400-grit sandpaper to lightly remove. Grease levels were not bad, and found the wiper post, for drivers side was not turning. I believe when we installed the wipers, the nut was tightened too much; pulling the post 'up' and binding the gear against the housing.
Just set it up on vise, and moved the nut to top of post, so I didi not damage any threads- and couple firm taps.... the post is now free and turns!! I have to grease it and reassemble- but I already tested motor and things are working.
Parnevik
Aug 21, 2017 10:04 PM
carelm
Mar 3, 2015 11:49 AM
chirt
Apr 22, 2014 10:15 AM
Jhartz
Mar 11, 2014 09:27 PM
sburgy4
Nov 27, 2009 08:56 AM
