Wire distributor- amplifier hole sealing?
Old Jun 23, 2020 | 12:02 PM
Joelerik's Avatar
Default Wire distributor- amplifier hole sealing?
Hi all!
There is a wire going from within the distributor through a hole in the distributor, to the amplifier. The wire runs through a rubber/plastic ”shunk” that seems to be there to seal the hole. Does this hole have to be 100% sealed? The ”shunk” is not doing that at the moment. In fact it is not sticking to the hole all that well. Should I add some sealant or glue or?
Have a nice evening!
Patrik, Sweden 1975 xjs
Old Jun 23, 2020 | 09:42 PM
Doug's Avatar
Best to keep the distributor as clean as possible just on general principles. Some ordinary RTV/silicone would be fine and, if carefully applied, wouldn't even look bad!
Old Jun 23, 2020 | 10:12 PM
What Doug said.
When I rewired mine, including those wires to the amp, the "blob" became trash.
I used Grey (it matches the colour of the alloy) RTV, and applied a small amount, let if almost dry, applied some more, shaped it a little, and so on, until the hole was all sealed.
Worked for me at the time.
Old Jun 24, 2020 | 07:15 AM
Joelerik's Avatar
Default Thank you!
Doug and Greg! Always very valuable inputs on my questions. Thank you for taking your time to help me out!
Brian Dailey
E type ( XK-E )
Jan 16, 2020 05:49 AM
anyoldiron
Sep 17, 2019 01:13 PM
Doug
Nov 6, 2016 03:45 PM
Wascator
May 22, 2013 09:35 PM
Vee
Jun 10, 2010 12:56 AM
