wires
Old Apr 29, 2016 | 09:53 AM
brinny's Avatar
Default wires
I have a couple of spare wires coming from the fuel sender unit loom. they are the two in picture laid on the carpet. I would be gratefull for any help in finding their location. thanks
Old Apr 29, 2016 | 10:44 AM
Greg in France's Avatar
The sender has three wires coming from it. One is an earth (black wire connected to the tab on the metal body of the sender unit). The other two go to the gauge (one is the low fuel warning light, the other works the gauge). In the boot RH corner somewhere will be the loom connectors for the two. Also check the earth wire goes to a good clean earth (normally found on the boot RHS exhaust tunnel top).
Greg
Old Apr 29, 2016 | 10:46 AM
Safari's Avatar
The picture is a bit small so my identification of the wires could be wrong but the two wires shown in the picture with the large boots on them look like the wires for the fuel pump. Are those the wires you are referring to?
Mark
Old Apr 29, 2016 | 11:08 AM
brinny's Avatar
yes those are the wires but the pump is connected?
Old Apr 29, 2016 | 12:02 PM
Brinny
Are the wires you want to know about connected to the fuel sender or to the fuel pump? You have said both so far!
Greg
Old Apr 29, 2016 | 12:15 PM
brinny's Avatar
I have 2 connected to the sender and 2 to the pump. I also have 2 spare as shown in the photo. I will try to post a bigger picture.
Old Apr 29, 2016 | 12:26 PM
Where is the other end of the wires that you want to know about connected to? Or at least where do they disappear to?
Greg
Old Apr 29, 2016 | 12:30 PM
brinny's Avatar
they disappear into the loom about 18" from the sender
Old Apr 29, 2016 | 02:31 PM
Brake buster's Avatar
my 89 car is exactly the same, two spare booted wires right where the fuel pump is located, never known what they are for , so not worried about them , lol
BB
Old Apr 29, 2016 | 05:13 PM
baxtor's Avatar
BB
My 89 too. I think the looms evolved as new components came into being/changed in some way but because a lot of these changes happened piecemeal rather than at a certain cut off point the looms sometimes needed to suit both setups.
Old Apr 30, 2016 | 01:56 AM
OK Brinny, I follow it now, apologies, I thought from your first post that they were attached to the sender. Maybe a CD changer loom wire? Or something needed on the convertibles?
Greg
Asdrewq
Apr 30, 2016 11:53 PM
JigJag
Apr 29, 2016 11:41 AM
Boeingtravel95
Apr 28, 2016 05:36 PM
harvest14
Apr 28, 2016 02:38 AM
malc4d
Apr 23, 2016 03:50 AM
