Wood trim removal
Old May 3, 2014 | 05:48 PM
Dr. Wood's Avatar
Default Wood trim removal
I have a 94 convertible that has the air bag on the rigt side where the glove box use to be and I would like to know how to remove the wood trim PC for refinishing. Also the center PC above the radio with the three clusters. Thanks..
Old May 5, 2014 | 05:33 PM
jnporcello's Avatar
Seach for a post called wood trim removal. I just did mine and there was some info looking there. Also Myrtle Productions in the UK has some videos. Most of the dash pry's off - with the exception of the glove box. I'm not sure about an air bag model, since I was lucky and didn't have to contend with that. The door panels need to be removed for the door trim.
Old May 5, 2014 | 06:05 PM
ptjs1's Avatar
Dr Wood,
Re: the centre panel. If you've got a trip computer fitted, you'll need to remove that first by removing the switch groups on the right and left and then reaching in through the holes to unscrew the trip computer mounts. Once all that is done, the panel is just held in by two plastic-gripped pins, one at each end which are an interference fit.
Good luck
Paul
I
Old May 5, 2014 | 07:02 PM
Vee's Avatar
Vee
Removing the Wood panel with the airbag behind it requires removal of the dash...
It's true.
Old May 5, 2014 | 09:07 PM
Dr. Wood's Avatar
Thanks for the info everyone.
Old Nov 13, 2014 | 06:15 PM
hoodun's Avatar
I refinished the wood in my 94 xjs. I wound up leaving the airbag cover in place.
I was able to refinish it in place and it came out well. Way easier than trying to remove it. Just sand it and refinish while covering the interior with some sort of plastic.
Old Nov 13, 2014 | 06:52 PM
jnporcello's Avatar
Nice. That's thinking outside the box. Have any pictures?
dsnyder586
Dec 29, 2024 07:39 PM
aholbro1
Dec 29, 2024 06:46 PM
Rivguy
Dec 4, 2020 07:55 AM
Nigels420G
Mark V - X 420G
Sep 17, 2015 10:29 AM
1964Daimler
Sep 9, 2015 11:28 AM
