X-pipe puzzle.
Old May 28, 2019 | 05:06 PM
JigJag's Avatar
Default X-pipe puzzle.
I have a puzzle I can’t solve. I want to place a x-pipe way up front on my XJS. Only spot available seems to be between bellhousing and trans pan. I’ve located a x-pipe that could fit the available space, and enter and exit between housing and tranny. Ceramic coated to avoid cooking anything. And, yes, I am thinking of running this pipe sideways. As shown below the two upper connections would be inputs. Not a normal installation.
But, My primary purpose is to render a V-12 note, and this pipe has a wide merge area, and not a true x. Ideally I’d have a single 2.5” pipe between two Ys. No room for that under this car.
Anyone here with X-pipe installed? Anyone with opinions as to the effectiveness of a large merger area vs a single tube? Any info or informed opinions would be appreciated!
Old May 28, 2019 | 06:08 PM
Crackerbuzz's Avatar
Yes I do. Can post pics in the next couple of days
Old May 28, 2019 | 06:46 PM
https://www.jaguarforums.com/forum/x...xhaust-204972/
Post #23 shows sound with X pipe
Old May 28, 2019 | 10:43 PM
Jagboi64's Avatar
Other thing that works is a simple pipe the bridges the two pipes just in front of the IRS. More of an H configuration.
Old May 29, 2019 | 03:30 AM
warrjon's Avatar
Firstly why do you want an X pipe.
Jaguar used an X pipe on the E Type but it was only to tune exhaust note. Unlike a 90° V8 crank the V12 has even pulses and will not benefit from an X pipe
Old May 29, 2019 | 05:20 AM
JigJag's Avatar
The only purpose for this x-pipe is sound.
I want dual exhausts with a V12 tempo. Not two sixes side by side.
The reason for the awkward desire to put this x up front is because I’m planning dual side pipes. There is no simpler exhaust setup than sidepipes, unless you want to join the two sides before they dump. This makes it weird.
Single side pipe works. But is not the look I want. So here I am trying to not loop the exhaust down and back again just to join the two banks.
2 1/2 inch pipes from down pipe on with 3” muffled core 60” pipes. Split between the two pipes decibels should be very reasonably calm at idle, but throaty. Higher RPMs should be glorious.
At at least that’s the plan.
Old May 29, 2019 | 07:06 AM
Doug's Avatar
I have mine just aft of the transmission. I have a Series III sedan but, from memory, I think the underbody layout is the same on on XJS
Old May 29, 2019 | 07:24 PM
I have done mine predominantly for sound also and have a similar set up top Doug's.
Old May 29, 2019 | 08:54 PM
JigJag's Avatar
That’s the practical way to do it.
Doug, do you have any ground clearance issues with this setup? What diameter are those pipes?
I don’t have to do sidepipes. But I will if I can sort this detail. I don’t want them if I have to have them separate.
jbudnick
Sep 20, 2014 10:54 AM
jagular
Aug 25, 2013 05:18 PM
Wolfy
Dec 10, 2011 01:17 AM
Peter M
Sep 17, 2010 03:58 PM
