Xjs 5.3 convertible fuel lines
Old Dec 12, 2017 | 03:32 PM
brinny's Avatar
Default Xjs 5.3 convertible fuel lines
I believe this may have been mentioned before by others but I will ad my two penneth as it may A. Help someone and B. Save someone some time and money. Please bear in mind I am uk based. In the course of restoring/ recommissioning my car I have renewed the fuel lines from the tank to the rail.After a lot of messing on my facelift car I discovered my local hydraulic hose shop. He has renewed the 3 hoses/ pipes on each side of the car for me. The flexi from the tank to the pipe that runs under the car , the under car steel pipe and the flexi from this pipe. The under car pipe has every bend duplicated and all hoses have been crimped and fittings replaced . Everything is of a correct spec. They charged me £55 per side which I Think was a gift especially when you see how well made they are. I'm obviously chuffed and am sharing this in the hope someone else may benefit like I have with the help I've received on this forum. Cheers lads
Old Dec 12, 2017 | 04:13 PM
orangeblossom's Avatar
Hi Brinny
Plus One on that!
I've never bought an OEM Hose, when I can have a bespoke one made at my local Hydraulic Shop as for one thing I can have a choice as to what
type of Hose they are going to use
Which whenever possible exceeds the OEM Spec and they can even make them up in that Aerostyle type of hose with the Stainless Steel outer Braiding
And as far as the Price goes they cannot be beat and are ridiculously cheap when compared to OEM and if they're good enough for a Tractor then
they are good enough for my Cat
Recently I had to have an Oil By-Pass Pipe made up, which you cannot buy off the Shelf, where the guy who made it gave me several pieces of Oil Pipe
With different numbers of Cores and all the Fittings, so I could cut the Pipe to the exact length required, where once having done so
He Crimped it altogether and only charged me £25 for the lot
Custom Made Oil By Pass Pipe only £25
Old Dec 13, 2017 | 01:47 AM
Greg in France's Avatar
Brilliant find Brinny.
A tip if your car is a pre-facelift. The high pressure line exits the boot at the RHS front corner. Then a short piece of steel tube goes up the rear of the wheelarch/chassis before it goes into a short flexible that allows the line to turn over the top of the axle. It is worth waxing this piece and then splitting a piece of rubber fuel hose and cable tieing it over this short solid piece between the boot exit and the flexible. This protects the pipe from stone damage from the wheels and general shot-blasting it otherwise gets.
Old Dec 13, 2017 | 02:17 PM
brinny's Avatar
Nice one Greg.
mirisisa
Dec 18, 2019 09:13 AM
MiniFarm
Oct 21, 2016 02:50 AM
ahunt4
Apr 15, 2015 04:48 AM
afterburner1
Feb 16, 2015 03:56 PM
Jaguila
Jan 20, 2014 08:01 PM
